20 Most Recent
Wacom Bamboo Fun USB Tablet with Cordless Pen and Mouse - Silver Questions & Answers
When I'm using Photoshop CS4
Go to Control Panel, and open bamboo properties. There you select the "pen" tab. In the pen tab you will see tracking. Select pen mode and details. You can map the pad there. After mapping pen mode try it in mouse mode as well. Best of luck!
It seems as if the clicker part is jammed.
when you use it have you tried pressing the shift button when it does it? sometimes it plays up on mine and it did when i used it on another computer. if not you might want to have it looked at by the place you bought it from xx
Tablet Pen wont work?
i had this problem for a while play with the settings or re-install it :) mine's back to normal now :) xxx
I have a Wacom Bamboo
It may be the USB port you're plugging into going bad. Try switching to plugging into a different USB port and see if that fixes the problem. If it doesn't it may be something faulty in the tablet itself and will still be covered by the manufacturer's warrenty. From my experience with Wacom, they're very prompt in fixing or replacing bad tablets.
Odd Cursor Movement with Tablet Pen
hello there, take the batteries out of you maouse and see if the problem persists. also, it seems as if cells phone interfere with some models of mice.
