20 Most Recent Saeco Odea Giro Espresso Maker - Black/Silver Questions & Answers
is the water available for brewing? are there enough beans for brewing? is there anything that shipped with the unit blocking the grounds?
Saeco Odea Giro... | Answered on Dec 15, 2016
everything what you have to do is to turn hot water to start,then after 10-15 seconds stop machine and turn it off. Wait about 10 minutes and rinse rest of descaling agent.Then fill the watertank with fresh water and rinse again trought hot water. When the water finish your machine is descaled.Then press hot water/steam button for 5-6 seconds and light go of. That is all.
Saeco Odea Giro... | Answered on Aug 11, 2014
Might need some urn cleaner to do a proper job. Scale is dry chemicals that you want remove so use the proper cleaning agent.
Saeco Odea Giro... | Answered on Aug 09, 2014
Make sure that you place the brew group the same way that you usually do after you take it out ie. make sure that the coffee grind collector is sitting vertically, and is depressed down. You may need to jiggle and move the pieces around for this to happen. Then make sure that you depress the tab in the center fully to the right until it clicks before trying to place it back in. Lastly, make sure that you clean any coffee grinds that may be sitting on the surface and which may prevent you from placing the brew group fully into the machine. Hope this helps, good luck!
Saeco Odea Giro... | Answered on Jul 10, 2014
Hi.
First turnthe machine on.
Then take out everything watertank, dreg draw and brewingunit and have the door opened to the brewing area.
have them out for about 1 minute and then put it back together again.
if this dosent help please check if the machine respond to removing the dregdraw, beanlid.
It will do it by making the constant red ligth flash instead.
if they respond make sure that the watertank is filled to max.
if that is the case it is the watertank sensor that is broken.
Saeco Odea Giro... | Answered on Jan 09, 2014
Make sure everything is fitted in place, there are several sensors that can bring the lamp to light. I have not heard that the water sensor is gone on Odea machine.
Can the machine run the selftest and can you see any water come out?
Hope this can help:
I managed to take mine apart because I was having a lot of leaking steam from the steam wand (as posted earlier). I followed your instructions, and all worked very well. Just to prepare readers, this is what I found. The green seal on the steam end was torn, as previously described. I noticed it start to "drag" a bit during use (daily for the past year), and it must have stuck and torn over time. See photos. I replaced with a part from ACE, see photo. Be sure to lube before re-assembly. Hope the photos help!
BA
Saeco Odea Giro... | Answered on Dec 23, 2013
if the grider is gone, it not start to grind beans!
Saeco Odea Giro... | Answered on Oct 21, 2013
So many faults can cause this problem.
The most common is the brew unit requires cleaning and regreasing as per the instruction manual.
Saeco Odea Giro... | Answered on Sep 26, 2013
Saeco Odea Giro Espresso Maker - Black/Silver Logo
Popular Tags
52 questions posted
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
ODEA Saeco
  • ODEA Saeco
Most Popular Question
saeco odea giro disassembly
  • Coffee Makers & Espresso Machines
