20 Most Recent
Copystar Kyocera FS-3640 MFP B/W Multifunction Printer Questions & Answers
How do i reset Error code C6020 on a Kyocera 8030 copier
This code is a high temperature in the fuser unit. The reset process is as follows, enter 1087-1087-163-print button-execute-print button then shut machine off when the message comes up on the display. The machine should clear the code and reboot, if the code returns you will need to contact a service company for further assistance. Hope this helps.
Copystar c2300 error code
You first need to pull the fuser out and manually check that it is running smoothly. More times than not, it will be the fuser rather than the motor.
If the fuser is fine, locate the motor then turn the machine on and visually inspect. If the motor does not run before the code pops up then replace it.
1135
Paper jam in the paper cassette
How to copy legal to letter on copystar CS 4005i
Make sure your default settings are for AUTO paper selection and 100% magnification to start. That is the most common default settings. Then, under "Zoom" change to AUTO magnification and under PAPER SELECTION specify Letter (either landscape or portrait). Now when you copy a legal original (8.5" x 14") it will be reduced at 78% to fit it on an 11" sheet. An alternative is to use "X-Y" zoom. Now you can stipulate 78% for the "X" dimension and leave the "Y" dimension at 100%. You will want letter size paper to be feeding lengthwise (portrait). Now you can copy legals and the image is reduced top-to-bottom only, leaving it much more readable.
