20 Most Recent
Universal Remote Control MX-780 48-Device Universal Remote Questions & Answers
How do I get the volume to work?
The MX-780 is not capable of sound. There are no options to create sound through the menu when you press and hold the MENU and ENTER button, nor is there in the CCP software. This probably has to do with limited memory and to conserve alkaline battery life. We get this question from some of our installers who we do programming work for. If there were some limited volume feedback it would probably be more annoying than helpful, and you might be looking to shut it off. The remotes in this price scale are usually a bunch of "Beeps" and "Blaps" that don't sound well and can be annoying. I hope this helps.
Regards,
Vincent
Total Control Remotes LLC
www.totalcontrolremotes.com
Mx 780 remote control channel and volume frozen
There could be many reasons why this happened. A corrupt or missing IR command, or the remote. An authorized dealer and programmer could help by uploading your configuration file and investigating; contact Total Control Remotes totalcontrolremotes.com for help.
Universal Remote MX-780
replace the batteries+retight the spring with plier for better contacts. clean it with alcohol isopropyl. and test again.If the problem persist use the digital camer or cell with camera, and iluminate the camera the LED will be ON, if do not, open the remote control, clean the keypads for corrosion, and use alcohol isopropyl . and test it again. God bless you
What is the code for ikon tv
028,022,027. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; that you want set-up code, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
I have RCA 4288 LED TV. How do I set universal remote control Chunghop 309sp to work on it?
Question edited for clarity and 'ECA' to 'RCA'.
Better to buy a Remote made for that television. No programming and same buttons as the old one.
https://www.google.com/search?q=RCA++4288+LED+TV+replacement+remote
Have a read
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Here are the codes if you wish to proceed with the Chinese Chunhop
- RCA TV 1000 , 1003 , 1004 , 1005 , 1006 , 1007 , 1019 , 1054 , 1055 , 1082 , 1096 , 1098 , 1099 , 1100 , 1101 , 1102 , 1103 , 1129 , 1179 ,1181 , 1188 , 1190 , 1196 , 1202 , 1203 , 1212 , 1215 , 1233 , 1257 , 1258 ,1266 , 1278 , 1279 , 1281 , 1286 , 1352
How to set up my philmore PM-RC18 UNIVERSAL REMOTE CONTROL
Setting up the Philmore PM-RC18 Universal Remote Control requires programming it with the appropriate codes for your devices. Here are the general steps for setting up the remote:
- Gather the necessary information: Before you start, you will need the brand and model numbers of the devices you want to control with the remote, such as your TV, DVD player, or audio system. Make sure you have this information handy as you will need it during the programming process.
- Power on the device: Turn on the device you want to control with the remote, whether it's your TV, DVD player, or audio system.
- Find the code list: The Philmore PM-RC18 remote control comes with a code list that contains the codes for various brands and models of devices. Look for the code list that came with your remote. It may be included in the user manual or available online on the manufacturer's website.
- Enter programming mode: Press and hold the "SET" button on the remote until the LED light on the remote turns on and remains lit. This indicates that the remote is now in programming mode.
- Enter the device code: Enter the appropriate device code for your device using the number buttons on the remote. The LED light on the remote should blink once to indicate that the code has been successfully entered.
- Test the remote: Point the remote at the device and press the "POWER" button. If the device turns off, it means the remote has successfully programmed with the correct code. If not, repeat the above steps with a different code from the list until you find the correct one.
- Store the code: Once you have successfully programmed the remote, press the "SET" button again to save the code. The LED light on the remote should turn off, indicating that the code has been stored.
- Test other functions: After programming the "POWER" button, try using other buttons on the remote, such as volume or channel buttons, to ensure that all the desired functions are working correctly.
- Repeat for other devices: If you want to control other devices, such as a DVD player or audio system, repeat the above steps with the appropriate device codes.
- Exit programming mode: Once you have finished programming all your devices, press the "SET" button one more time to exit programming mode. The LED light on the remote should turn off.
Note: If you are unable to find the correct code for your device in the code list, the Philmore PM-RC18 remote also has a "code search" function that allows you to search for the correct code manually. Refer to the user manual or online resources for instructions on how to use the code search function. If you encounter any issues or difficulties during the setup process, refer to the user manual or contact Philmore customer support for further assistance.
