20 Most Recent
Barbeques Galore Cook-On Complete Kitchen 4-Burner 167900 (NG) Grill Questions & Answers
Burning Hot and Burning propane tank empty in 2 to 3 uses
What does "and parts to burners" mean? it sounds like you have NG orifices on a LP appliance or the LP orifices are not properly drilled. I use my barbecue several times a week and exchange an LP cylinder about every 6 months. If you are using the grill twice and the cylinder is empty that is not a lot of burning, that is a leak.
to adjust the burner the first and most obvious place to look is to check the pressure on the regulator (LP is 11") and the orifices. Next are there adjustment screws inside the valve stems? if so light the barbecue so the flames are visible and insert a long flat-head screwdriver to adjust the set screw inside the valve stem. turn the valve to "low" and adjust it until the flames are just barely staying on. Leave the set screw in that position and turn the valve on high, close the lid. if you're over 400 degrees in 10 minutes you'll be fine. if not adjust the set screw up a quarter turn at a time.
