20 Most Recent
Orion LCD TV SLED2480 Sansui - 24" LED-backlit Questions & Answers
How to connect tv, direct tv box, and home theater together properly ?
Hi Vincent
That would be a heap of detail to go into. Time consuming...
Hopefully this quick pointer might help.
What is HDMI
High Definition MultiMedia Interface
Note the word MultiMedia
This Means....Both HD Video & Sound through the one cable.
HDMI is the latest state of the art connection.
Use this wherever possible. It's made for High Definition
More Convenient
Use a HDMI cable from one device to the other wherever both devices have that port type (connector).
You don't have to pay a premium ridiculous price for HDMI Cables as in the Monster type. Overpriced.
Well made regular brand & Gold pins are nice. Keep them Short.
Long Cables loose quality. 1 Meter is default.
Your LCD TV should have more than one HDMI port for inputting & outputting media (sound & video)
HDMI can be used for INPUT or OUTPUT
Eg OUT to an Amplifier or IN from a device like DVD Player.
On the OLDer equipment you will Have a YELLOW connector. That is used for the Video signal.
The RED is RIGHT AUDIO.
The WHITE is LEFT AUDIO.
Fiber OPTIC cables are a better way to transfer AUDIO than the red & white cables. Cleaner.
But this only works if the 2 devices have an optical port available.
Some New Amplifiers are smart and may require you to select the optical port in the settings instead of the default HDMI.
This may also apply to HDMI Port Choice.
Simply plug the HDMI in first & check.
Use a known source e.g. play a DVD or CD or Radio Reveiver as a signal.
ONE HDMI Port on the TV might be an OUTPUT ONLY channel (PORT) to an External Amplifier (if you wish to use one)
HDMI on external devices will be Outputing video & sound on their HDMI Port
To the INPUT HDMI PORTS on the TV.
Some TV's will fall back to a particular HDMI port on power fail or startup therefore not requiring you to use the remote every time.
External SPEAKERS should have the polarity checked. Eg Red (or marked wire) to the same post on either speaker. This makes sure that the speakers travel forward together at the same time. Pumping sound forward then retracting together....
so they are not fighting against each other.
.......This is called out of phase & distorts sound.
Hope this Helps
Enjoy Your New Entertainment
Was this Helpful
.......Then give me a tick of approval for my trouble....
Cheers
HDMI Wikipedia the free encyclopedia
How to change from analog to digital
If you have an old analogue TV and wish to keep it, buy a digital set top box (which is just a digital tuner with no screen), then connect the antenna and TV to that. These STBs are quite cheap, and a good name brand will give you an excellent picture, with one qualification.
This is that the old analogue TVs have a screen proportion of 4:3, whereas the digital broadcasts are 16:9. So by keeping an old screen you will lose a bit of the picture at each side, or see a black band at top and bottom.
If you don't like that, you will need to buy a flat-screen (digital) TV and toss out the old one. There is a huge range of sizes and prices, so if you look for a special from a recognised retailer who will stand by the warranty, you would be OK.
Can I hook a genie Wi-Fi camera up to this TV, ORION MODEL NO:TVDVD092
It's possible to connect a Wi-Fi security camera to a TV, but whether or not it will work with your specific TV model will depend on the capabilities of the TV and the camera. In general, most modern TVs have built-in Wi-Fi connectivity and support for applications like Netflix and Hulu, which allow you to stream video from the internet directly to your TV. However, not all TVs support all types of Wi-Fi cameras, and some cameras may require additional hardware or software in order to be used with a TV.
In order to connect a Wi-Fi security camera to your TV, you will need to check the specifications and compatibility of both the camera and the TV. If your TV has built-in Wi-Fi and support for streaming applications, it may be possible to connect the camera directly to the TV using the Wi-Fi network. Alternatively, you may be able to connect the camera to a computer or mobile device and then use an HDMI cable to connect the computer or mobile device to the TV.
In summary, it's possible to connect a Wi-Fi security camera to a TV, but whether or not it will work with your specific TV model will depend on the capabilities of the TV and the camera. It's best to check the specifications and compatibility of both the camera and the TV in order to determine the best way to connect them.
Can a wifi geeni camera be set up to my ORION MODEL NO:: TVDVD092
It is not possible to directly connect a Wi-Fi Geeni camera to an Orion TV model number TVDVD092. The Orion TV model you have mentioned is a television set that is not capable of connecting to a Wi-Fi network or functioning as a Wi-Fi network device. In order to use a Wi-Fi Geeni camera, you would need a device that is capable of connecting to a Wi-Fi network, such as a smartphone, tablet, or computer. You can then use the Geeni app on that device to set up and control the camera.
