20 Most Recent LG 6632L-0420A Backlight Inverter PPW-EE320S-0 Questions & Answers
You have this backwards. The applicable code would be in the remote control, if it is compatible.
LG Televison &... | Answered 12 hours ago
Cant order screens. Not cost effective
LG Televison &... | Answered 15 hours ago
The most logical problematic thing would be Sweep circuit board on the TV. However it could be a loose ribbon cable or connection. The worst scenario would be A cracked screen. Good luck
LG Televison &... | Answered 2 days ago
Your upper Y-drive buffer board has failed and will need to be replaced. Take it to a repair technician for an estimate if you are not comfortable doing the work.
LG Televison &... | Answered on Jun 11, 2019
i do not it biss key
LG Televison &... | Answered on Jun 10, 2019
Buy a new TV
LG Televison &... | Answered on Jun 09, 2019
Without a remote control, you can't power it ON. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
LG Televison &... | Answered on Jun 08, 2019
which model/size, date of manufacture, etc of LG? it may be the logic card.does the tv control menu come up?
LG Televison &... | Answered on Jun 07, 2019
Hello Jim, for what you comment, your Blu Ray, would have reader problems, dish motor or controller
I suggest you look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Jim, por lo que comentas, tu Blu Ray, tendr?a problemas de lector, motor de plato o controlador
Te sugiero busques un servicio t?cnico especializado
Espero Puedas resolver el problema
Saludos Franco Dosil
LG Televison &... | Answered on Jun 06, 2019
It would depend on the cord that plugs into the tv. If you have the red, yellow, and white that plugs in then the video cable needs to be plugged in. You need to plug in the video cord. It sounds like you only have the audio cable plugged in. Try a hdmi if there is a outlet for it.
As with most modern TVs the sound is poor. Connect it to your home stereo system.
Hello Steve, for what you are saying, it could be that some light diffuser has been detached from the back lighting, to see if that is what you can try, turn the TV and try to listen if there is something loose, if so, you should disarm the television until you reach the back lighting and paste the diffusers in the corresponding places, check that the rest of the diffusers of the LED strips are firm, so that the problem does not happen again
If you hear something loose and you do not have knowledge of how to disarm, look for a specialized technical service
Hola Steve, por lo que comentas, podr?a ser que se haya desprendido alg?n difusor de luz, de la iluminaci?n trasera, para comprobar si es eso puedes probar, girar el televisor y tratar de escuchar si hay algo suelto, si es as?, deber?as desarmar el televisor hasta llegar a la iluminaci?n trasera y pegar los difusores el los lugares que corresponden, comprueba que el resto de los difusores de las tiras de LED, se encuentren firmes, para que no vuelva a ocurrir el problema
Si escuchas algo suelto y no tienes conocimientos de como desarmar, busca un servicio t?cnico especializado
Espero puedas resolver el problema
LG Televison &... | Answered on Jun 05, 2019
Hello Terri, for what you are saying, the new DVD player, could be playing in standard PAL B, you should check in the menu of your TV how the color system is selected, if it is in NTSC, you should pass it to automatic and in that position you should see everything you see, in color
Discuss the brand and model of the TV and the model of the LG DVD player, to see if the best possible solution can be found
Hola Terri, por lo que comentas, el nuevo reproductor de DVD, podr?a estar reproduciendo en norma PAL B, deber?as revisar en el men? de tu televisor como esta seleccionado el sistema de color, si esta en NTSC, debes pasarlo a autom?tico y en esa posici?n deber?as ver todo lo que mires, en color
Comenta la marca y modelo del televisor y el modelo del reproductor del DVD LG, para ver si se puede encontrar la mejor soluci?n posible
Espero que puedas resolver el problema
moved you out of computers, its not.
why just do Netflix, there are like 1000 streaming sources online, now, try more, like vudu, hulu, amazon, or 1000 of free ones. endless. to try, in the LG app screen for players, see em?
did you speed test your unstated ISP connections?
did you try the TV using hard wired to router with ethernet cable.?
use wifi test last, wifi is problematic.
if wifi tv is far from router it will be slow.
if wifi is overloaded in your HOOD , then it will be slow.
own a PC, try it yet, connected wifi and for sure ethernet
see it or runs Netflix and say 5 others ok ?
run Inssider.exe program see of wifi is jammed up?
not once did you say wifi, and I bet it is.
we have a gigalan , ethernet jack in every room here.
I pulled all land line cables and switch them all to ethernet
so now if wifi goes NUTS, wired works.
btw, wired not one error in 2 years, not even that pesky buffering error, on Netflix.
gee even NEflix has speed test to see if HD mode even works.
for you.
if others in your home are tying up wifi gee, there you go.
wifi is shared resource,
good luck
LG 6632L-0420A Backlight Inverter PPW-EE320S-0 Logo
1 questions posted
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
just replaced power supply led
  • Televison & Video
