All questions on Fixya need 'make model (what it is)' as first 3 words.
You posted to the category 'Kodak Televisions', there are over 10,000 categories to choose from, but let's make a wild guess that this is a Camera because that is what Google says you have. Although it could be a Copier, a Photo Printer, or even a Baby Monitor who knows, we can only guess.
https://support.kodaksmarthome.com > en-us > articles
Wait for the camera LED to start blinking BLUE slowly (this means the reset is successful); Turn on the parent unit and check if the camera is still paired and ...
Kodakhttps://www.kodak.com > content > Consumer
PDF
Do not point the flash close to anyone's eyes. ... Each pack of KODAK ZINK Photo Paper includes a blue Color Calibration Sheet. Make sure the.
16 pages
fccid.iohttps://fccid.io > User-Manual
PDF
The first LED lights up in blue when the adapter is plugged in and it's fully charged; the second LED lights up in green when the Parent Unit is switched on.
40 pages
Hi i actually have one you can have from an old portable dvd player, or you can salvage one from a faulty cd player / dvd player as they are standard, just be careful when prying them off the dvd spindle motor as you can easily bend the shaft.
jon
Check the internet connection. The television can't update if it can't see the internet. Resetting it breaks the previous settings.
Just for fun, reboot the router as well and wait 15 minutes until all the lights come back on. Then reestablish the television connection to the router.
Harwa is not a make we know here in North America.
https://www.google.com/search?q=Harwa+Smart+television.+How+to+restore+Apps
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DIY or replace with good used unit.
