20 Most Recent
MA Audio HK1997 Car Audio Amplifier Questions & Answers
Moved while on
Its likely a fuse has blown.
Check all the fuses that are needed to supply power, even the remote power.
If this does not work, you should supply more info on your system.
Do you have power? etc.
Audio speakers
Have you installed Kicker capacitors? With the extra power you have you will need them to help with the load.
My speakers r not working.
on some cases you can but if its your falut that they ripped more then likely they want to repair or replace and you have to have a warranty on the subs to have them do anything with them so car place will soilder them back together if there some wire coming off the sub
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
