20 Most Recent Emerson Used Original NH200UD Remote Control Questions & Answers
Remote won't change volume, channel numbers don't work
IF its the original remote for the device, the circuit board is just dirty and is not getting good contact. If its a universal then the codes may not be 100% compatible with the device or the remote isn't 100% compatible either.
1/23/2014 4:44:38 AM • Emerson Used... • Answered on Jan 23, 2014
How to setup a onn remote control to a emerson TV
1. Turn on your Emerson TV. 2. Consult the ONN remote manual for Emerson TV codes. 3. Press TV on the ONN remote. 4. Enter the correct code. 5. Test remote functions. - If unsuccessful, try code search or auto-programming. 6. Ensure compatibility.
1/8/2024 3:58:07 PM • Emerson... • Answered on Jan 08, 2024
I have a ONN remote model CR-55A1 . I want to setup it up to control my Emerson Television.
I can't find anything that says what the DR-55A1 is? Is it a Onn Universal Remote or to a specific item like a DVD or ONN Television? If it is, you can't do that, one device, one code. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
onnremotes
ONN Remote Control https://www.onnremotes.com Your ONN remote can control up to 6 devices and is remarkably easy to set up. These video tutorials will give you step-by-step instructions for programming the ... Missing: 55A1 ‎' Show results with: 55A1 ..
1/8/2024 2:15:46 AM • Emerson... • Answered on Jan 08, 2024
QR code for 55" Emerson tv model LF501EM4A
No idea what you mean and neither does Google. Why do you want a QR Code? https://www.google.com/search?q=Emerson+LF501EM4A+QR+code https://www.google.com/search?q=Emerson+LF501EM4A ..
1/2/2024 9:29:02 PM • Emerson... • Answered on Jan 02, 2024
Emerson Cks3516 SmartSet Dual-Alarm Clock Radio stopped working properly. Projection showed 8:88 am. Unplugged and replugged in. Now projection doesn't turn on. Help?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjT3Z6wx5SCAxUTrYkEHRSLDXMQFnoECBwQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft29937234-emerson_cks3516_smartset_dual_alarm&usg=AOvVaw0jD-XY5Po6uxNflfX6Ep8g&opi=89978449
10/26/2023 8:32:11 PM • Emerson... • Answered on Oct 26, 2023
How do you factory reset an Emerson tv LC320EMX without a remote??
Refer to Page 6 of user manual (Introduction). ManualsLib - Makes it easy to find manuals online! Manual switches on the side of TV can be used instead of remote control.
10/17/2023 9:15:42 AM • Emerson... • Answered on Oct 17, 2023
Emerson TV shuts off after logo, how to fix?
This is a boot log error, replace the main board and it should work.
8/24/2023 2:56:57 PM • Emerson... • Answered on Aug 24, 2023
2answers
Emerson LHD32K20US television. I need to hook up DVD player. I can't find the channel for my player?
I can't find a manual for it, but normally you don't search for 'Channels'. The DVD Player is connected via an HDMI socket in the television and you use the Source or Input Button on the Remote to find the HDMI Socket that the DVD player is connected to. They are normally number on the set HDMI 1, HDMI 2 etc., As you click through, you will see the HDMI input number flashed on the screen. https://www.google.com/search?q=emerson+lhd32k20us+manual ..
7/8/2023 6:28:43 PM • Emerson... • Answered on Jul 08, 2023
My Emerson DVD player says Disc Error Playback feature may not be available on this disc
The error message "Disc Error Playback feature may not be available on this disc" can have a few different causes. Here are some of the most common:
  • The disc is not compatible with the DVD player. Some DVD players are only compatible with certain regions or formats of discs. If the disc you are trying to play is not compatible with your DVD player, you will get this error message.
  • The disc is damaged. If the disc is scratched, dirty, or otherwise damaged, it may not be able to be read by the DVD player.
  • The DVD player is faulty. If the DVD player is faulty, it may not be able to read discs correctly.
Here are some things you can try to fix the problem:
  • Try playing the disc in another DVD player. If the disc plays in another DVD player, then the problem is with your DVD player.
  • Clean the disc. Use a soft, dry cloth to clean the disc. Be careful not to scratch the disc.
  • Format the disc. If the disc is formatted for a different region or format, you may need to format it for your DVD player.
  • Reset the DVD player. If the DVD player is faulty, you may need to reset it.
If you have tried all of these things and you are still getting the error message, then you may need to replace the DVD player.
7/6/2023 7:52:52 PM • Emerson... • Answered on Jul 06, 2023
Anyone know the start and run cap values on an Emerson LR63596 model T63XWBSS1486, labels have deteriorated
The capacitor values for the Emerson LR63596 model T63XWBSS1486 motor will depend on the specific application and the motor's specifications. Without more information about the motor's voltage, horsepower, and other details, it's difficult to give a precise answer. However, as a general rule, the capacitor values for single-phase AC motors like the Emerson LR63596 typically range from around 5-80 microfarads (µF) for the start capacitor, and 5-100 µF for the run capacitor. That being said, it's important to note that the specific capacitor values required for your motor may be different, and using the wrong values could cause damage to the motor or affect its performance. Therefore, it's recommended to consult the motor's documentation or a qualified technician to determine the correct capacitor values for your specific application.
6/27/2023 5:47:05 PM • Emerson... • Answered on Jun 27, 2023
Where are fuses on a Emerson TV model # LD190EM2
Fuses are solder in, and chances of a fuse blowing without other bad components are slim, take it in for service or better yet buy a new TV unless you have a multimeter and know how to trouble shoot a tv
6/25/2023 4:56:05 PM • Emerson... • Answered on Jun 25, 2023
Emerson LC195EM9 did channel search and all channels vanished Now do channel search and no channels registered signals have new amplified leadzm antenna with in line amplifier
1st make sure your tv is in antenna mode in settings, then take out the seperate amp run direct and try again famous with china placement of antenna is very imortant but you should get at least a couple.close channels. Now all this is providing it was working before https://irionstvshop.com
5/31/2023 12:20:30 PM • Emerson... • Answered on May 31, 2023
Emerson LTDN42V68US television will not power on. The light just blinks red continuously ..
What's happening with your TV is the backlight inverter is sensing over current and shutting the entire power supply down (excluding the standby supply) this gives the 1 blink code. Reason for over current is open circuit in the LED backlights, you will need to replace the lamps to fix the issue, there is about a 2% chance of it being a faulty power supply but in most cases it's the lamps. This is common on most Funai brand sets.
4/8/2023 3:47:08 PM • Emerson... • Answered on Apr 08, 2023
2answers
How do I connect a soundbar to my Emerson TV?
Use the headphone input on the TV.
3/12/2023 3:22:55 PM • Emerson... • Answered on Mar 12, 2023
How come my Daewoo remote 97p1803700 will not work anymore?
The issue with your Daewoo remote 97p1803700 may be due to battery depletion, broken buttons, or internal damage. To resolve the issue, you could try changing the batteries, checking the buttons for any physical damage, and cleaning the interior of the remote control. If these steps do not resolve the issue, you may need to take the remote control to a professional repair service. As for the eject button, the functionality may be limited by the remote control model and the device it is controlling. It may not be possible to add an eject button to your current remote control, but you could look for alternative remote control models that offer the eject button
2/3/2023 5:31:22 PM • Emerson... • Answered on Feb 03, 2023
2answers
Connect to Emerson tv to remote?
To connect your Emerson TV to a remote control, you can follow these steps:
  1. Make sure the batteries are properly inserted in the remote control.
  2. Turn on the TV.
  3. Locate the remote control sensor on the TV.
  4. Point the remote control directly at the sensor and press any button to see if the remote is working.
  5. If the remote is not working, try changing the batteries or resetting the remote control.
If you are still having trouble connecting the remote to your Emerson TV, you may need to consult the TV's manual or contact the manufacturer for further assistance.
2/1/2023 3:48:51 PM • Emerson... • Answered on Feb 01, 2023
2answers
How to change the resolution on a Emerson tv?
What is your video source? I have only seen this message on TVs when a connected set top box was set to an unusable resolution. (For example, a set top box set to progressive scan when the TV can only handle interlaced scan. For a full HD video source these would be labeled 1080i or 1080p. There might be other characters in the settings menu list, depending on the source.) When my cable box did this when using an HDMI cable, the simplest solution for me was to connect the cable box to the TV using a RF cable. Both the set top box and the TV had RF connections. My TV has both a menu button and a source button on the front panel. I set the source to TV. Then I was able to tune to channel 3; channel 4 can work. (Scanning for channels from the on-screen menu was available without a remote.) Then I used the set top box's remote to access that menu. Then I got to Settings > Hardware Settings > Video. Then I could change the output video resolution for HDMI back to 1080i. This is harder with some of the streaming devices with only an HDMI connection. I hope this helps. Please add a comment to let me know which model TV and device have the resolution mismatch for additional steps to resolve the problem. Cindy Wells
1/31/2023 2:04:32 AM • Emerson... • Answered on Jan 31, 2023
When did the Emerson vcr model EV 306N come out and when did they introduce it ?
Based on the information you've provided, it appears that your Emerson EV 306N VCR was manufactured by Daewoo in Korea. The serial number you've provided suggests that the unit was manufactured in 1982. The FCC ID and UL File No. suggest that the unit has been approved by the Federal Communications Commission (FCC) and the Underwriters Laboratories (UL), respectively. It is an old VCR model and it might not have all the features of modern VCRs, such as the ability to record in stereo or play back in widescreen. Also, it might not be compatible with new recording formats like DVD or digital television. I would recommend searching online for a user manual or contacting Emerson directly for more information about your specific model.
1/13/2023 7:14:53 AM • Emerson... • Answered on Jan 13, 2023
Emerson LC320EM1F no display
  1. Check the power supply: The power supply is responsible for providing power to the various components of the TV. If the power supply is damaged or malfunctioning, it could be causing the issue you are experiencing. Test the power supply to see if it is functioning properly.
  2. Check the main board: The main board is the central hub of the TV and controls many of its functions. If the main board is damaged or malfunctioning, it could be causing the issue you are experiencing. Test the main board to see if it is functioning properly.
  3. Check the display panel: The display panel is the component responsible for displaying the image on the TV. If the display panel is damaged or malfunctioning, it could be causing the issue you are experiencing. Test the display panel to see if it is functioning properly.
1/3/2023 10:53:23 PM • Emerson... • Answered on Jan 03, 2023
Emerson Used Original NH200UD Remote Control Logo
1 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
remote change volume channel numbers
  • Televison & Video
