20 Most Recent
Audiovox Universal Remote, NaviLight 6, 1 remote Questions & Answers
Blue light on antenna isn't turning on remote start won't work.
It's possible that the issue with your Audiovox pursuit PRO9056c remote start system is related to the antenna or its connection. Here are a few things you can try to troubleshoot the issue:
- Check the antenna connection: Make sure the antenna is properly connected to the control module of the remote start system. You may need to remove the panel where the antenna is mounted to access the wiring and connections. Check the wiring for any signs of damage or corrosion, and make sure the connections are tight.
- Check the fuse: The remote start system may have a fuse that is responsible for powering the antenna. Check the fuse to make sure it is not blown or damaged.
- Reset the system: Try resetting the remote start system by disconnecting the battery for a few minutes, then reconnecting it. This may help reset the system and resolve any issues that were causing it to malfunction.
- Consult a professional: If you are not familiar with automotive electronics or are unable to resolve the issue with the above steps, it may be best to consult with a professional technician who can diagnose and repair the system for you.
It's also possible that there is a problem with the remote start system itself, such as a malfunctioning control module
2/16/2023 10:58:50 PM •
Audiovox...
Answered
on Feb 16, 2023
I have a Audiovox d1988 and the screen won't play. I have sound but no picture. Help!!!
Jim,
First thing I would do is try a different DVD to see if the problem persists. Otherwise, this device is equipped with integrated speakers, meaning it is unlikely that you will be able to replace them. You may be in the market for a new Audiovox, unfortunately; but before you scrap it I suggest taking it to a local electronic repair store near you.
Hope this helps,
Best regards
3/8/2019 11:36:14 PM •
Audiovox...
Answered
on Mar 08, 2019
Looking for code to use universal remote on 12v. audiovox TV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device
12/14/2017 9:52:31 AM •
Audiovox...
Answered
on Dec 14, 2017
