20 Most Recent Char-Broil 463220004 Grill Questions & Answers
the regulator could have gone into lock up.
try this to unlock it...
  1. Open the BBQ Lid
  2. Turn ALL main control knobs to the "OFF"/CLOSED position
  3. Turn the Propane tank valve to the "OFF"/CLOSED position
  4. Disconnect the Regulator hose from the Propane tank
  5. Turn ALL main control knobs to the "ON"/OPEN position
  6. Let stand for 1-2 minutes, allowing all excess gas in valves and manifold to dissipate
  7. Turn ALL control knob back to the "OFF"/CLOSED position
  8. Reconnect the regulator hose to the Propane tank- hand tighten only.
  9. Check all hose connections to ensure that a positive seal has been made
  10. SLOWLY turn "ON"/OPEN the propane gas supply
  11. Wait approximately 5 seconds for the regulator pressure to stabilize
  12. Turn "ON"/OPEN the selected burner control knob to "HI"
  13. Press the Multi Spark ignition button or match light selected burner.
  14. Hope this helps you has me in the past!
Char-Broil... | Answered on Jan 08, 2018
Definately sounds like a manufacture defect. I would try to return grill.
Char-Broil... | Answered on Sep 03, 2010
May I get the make and model # to help you more.
Char-Broil... | Answered on Apr 13, 2010
Not a year old and u have documentation. DO NOT TOUCH ANY FURTHER. Call your Viking authorized servicer and they will fix it for free! If you have no documentation ex. bill of sale, install date, move in date etc., try unplugging the holes with a paper clip to let the gas flow. Did it work before? If not then check ur model # and make sure you have an LP unit and not a NG unit. Your orifices maybe the wrong ones. Anyways, you should call service since you are under the manufactures warranty.
Char-Broil... | Answered on Sep 04, 2009
Im not sure where to go for parts but We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff will remove the rust and truely clean your surface.
Char-Broil... | Answered on Aug 24, 2009
Hi, Sorry but nobody wants to give bad news. There is a tube that comes from the control knob to the orifice that controls the amount of gas to the burners, my guess without being able to look at it is that the orifice broke at the connection to the tube and the flames are shooting back toward the knob. However it is possible that the venturi opening ( the screened part on the burner tube that sets on the orifice ) became dislodged. Either way you need to remove the grate, remove the burner assembly and then look ( under the cart from the back) at the tube and orifice for damage. You do not indicate how old any of this is and they do rust out. Parts are available but you have to determine if based on age and damage you want to replace any of it or all of it. If you inspect it and find something that you think you can fix you can get back to us for more help. If it is as simple as the dislodged tube and the parts are OK, reseat it and check it out. I wish you the best of Luck!
Char-Broil... | Answered on Apr 25, 2009
A Dremel tool with a brass or steel wire brush works wonders.
Char-Broil... | Answered on Dec 27, 2018
try amazon for a replacement sparker
Char-Broil... | Answered on Jul 10, 2018
Igniter is combined in the valve of grill so the best way is change the new one. or cross flame from other burner.
Your venturi could be clogged up. clean the burner holes with a straightened paperclip, then take the burners out and do the same to the venturi that deliver gas to the burners. If that doesn't do it, you may have a bad regulator.
Char-Broil... | Answered on Mar 02, 2018
why don't you state the problem first. what is not working?
Char-Broil... | Answered on Oct 01, 2017
I hade the same problem! the new propane bottles the valve inside where it screws in it wont open
all the way?.
Char-Broil... | Answered on Jun 22, 2017
Depends on your cooking preference.
Char-Broil... | Answered on Apr 23, 2017
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Char-Broil... | Answered on Aug 03, 2016
Char-Broil 463220004 Grill Logo
Popular Tags
7 questions posted
Top Char-Broil Grilling Experts
Paul Carew
Steve Allison
Steve Allison
Dave Cottrell
Dave Cottrell
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
View Most Popular
Char-Broil Grilling
  • Char-Broil Grilling
Most Popular Question
right knob melted
  • Grilling
