FixYa.com
Dacor ECS127 Epicure Stainless Steel Electric Single Oven
All Products > Dacor > Ovens
Problems with Dacor ECS127 Epicure Stainless Steel Electric Single Oven?
Troubleshooting and Support
Solved Problems for Dacor ECS127 Epicure Stainless Steel Electric Single Oven RSS Feed Post a New Problem
Oven light
The oven light switches off and on repeatedly spontaneously. When I swtich off the power, the problem stops for a short...
1 Solution
Oven light flickers on and off rapidly
The oven light used to occasionally turn itself on and off. Today, while the oven was in use, the light started...
1 Solution
dacor oven ECPS127S will not heat after...
the oven went into self clean mode for 2 hours> it worked flawlessly. after the self cleaning mode and cool down, the...
1 Solution
Inside Window Replacement
The inside window of me DACOR cracked and I have the replacement part but for the life of me I can't figure out how to...
1 Solution
LED FRROZEN
While cooking, the LED display is frozen and says 0 degrees and pushing the buttons do nothing
1 Solution
condensation
When using top oven, condensation forms on the top of the bottom door oven. Have only had oven a short time.
1 Solution
Dacor Oven - convection fan stays on while...
When I try to "bake" the convection fan comes on, and stays on, continuously. The manual said it should cut...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Dacor ECS127 Epicure Stainless Steel Electric Single Oven RSS Feed Post a New Problem
F1 flashing signal & continual...
My single Dacor oven is making a continual bleeping noise with an "F1" appearing on the right hand side in the...
Post a Solution
Excessive condensation
I get excessive condensation on the inside surface of my built-in oven door. It is so serious that it leaks out of the...
Post a Solution
Door open adjustment
the door on my oven seems to be slightly open during cook cycles, how do I adjust it?
Post a Solution
oven showing f4 even after replacement of...
chain of events. oven stopped working, I had repair company come out and they said I needed a new control board (they...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Self CleaningWith Self Cleaning
Oven FunctionalityBake · Broil
Oven TypeSingle
Energy SourceElectric
Microwave FunctionWithout Microwave Function
Other Features
Capacity3.4 cu/ ft
Number of Racks3
Sabbath ModeWith Sabbath Mode
Dimensions
Overall Height28.38 in.
Overall Width27 in.
Warranty
Warranty2 Years
Dacor Contact Information
Main support number800-793-0093
Support FAX626-441-9632
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
