20 Most Recent
RCA 22LA45RQGB 22 Class LCD HDTV - 1080p, 1920 x 1080, 16:9, 1000:1, 5 Questions & Answers
Rca tablet is frozen
Same with me but it got cracked so I brung it inside and it froze idk what to do :(
Forgot password
You'll need to do a factory reset:
1. With the device off, press and hold Volume
Up and Power.
2. Release the Power button
when you see the logo, but continue to hold Volume Up until
the recovery screen appears.
3. Use the Volume buttons to navigate the menu
and select wipe data / factory reset. Press Home to
choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however
anything on your SD card will still remain.
At this point you will need to start fresh as if you just
bought the device -- register with your email address, etc.
Rca tablet will not turn on
If you look on the back of your tablet. You should see a tiny word that reads "reset" the hole Is tiny so using a earring to press it will turn it on. After that it should turn on then plug it up to the charger. My tablet does it so I have to do it alot.
My RCA tablet died and it wont turn back on
If you have the correct charger, let the tablet charge for a full 24hrs, actually i think 10hrs will be ok and try turning it on, also you can google how to do a reset for your exact model tablet. I have another brand tablet and that worked.
It goes to the rca loding logo and keeps loadin until dead
do you have the correct charger, because if it doesn't and you are charging using usb, it may not be charging it enough, if you have the correct charger You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Wont finish its loading process
Troubleshoot
You may have to reset it. With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset. (make sure it is fully charged before you do the reset.
Tablet will not charge or turn on
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset. if this doesn't work your charging port may be lossened or damaged, have a technician check it.
