20 Most Recent Dodge 2004 Stratus SXT Questions & Answers
Hi Tom.
It sounds like your IAC, ( Idle Air Control Valve), is not properly controlling the Idle speed of your engine. Try removing the IAC Valve and clean the pintle of carbon build-up. The ECM (Engine Control Module), cannot properly adjust engine Idle if the valve tip has excessive carbon build up on it. If you clean the pintle make sure the tip is less than an inch and an eighth, (1 1/8) from the shoulder to the pintle tip. This is to prevent damage when re-installing it. Retract the spring and spin the pintle inward to set the depth. If this does not work replace the Idle Air Control Valve. Hope this helps.
Dodge 2004... | Answered on May 28, 2017
The engine computer controls the coils.
Dodge 2004... | Answered on Mar 12, 2015
Dodge Computers... | Answered on May 20, 2018
Check your fuel pump. Make sure that that is working. Because if its not then the car wont start because of this.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_a4640839dbb7ec58
Dodge Computers... | Answered on Mar 17, 2018
Bluetooth drivers are provided with the device.
Computers &... | Answered 2 minutes ago
If you have bought the DVD and just copy it for your personal using, i think it should be legal. You can use this DVD creator, it can perfectly copy protected DVD.
Computers &... | Answered 5 hours ago
DVD movies are usually copy protected and cannot be copied without a DVD copy program that removes the copy protection.
You also need a DVD burning drive installed in your ASUS.
DVDFab is one of the best DVD burning programs available, I use and recommend it.
Go this this WEB site to download, it is available for a try before you buy basis.
http://www.dvdfab.com/
Which Program? There is a difference between Burn and Copy.
Copy means you have a CD or DvD that already has something on it such as a music CD or a movie DvD and you want to copy it. The system normally reads the CD or DvD and copies the contents to disk then asks you to put in a blank CD or DvD to make the copy.
Burn means you have Data Files, Documents or Music that is already on the disk drive and you want to put it on a Cd or DvD. Normally you just put in a blank CD or DvD then either Drop and Drag, Browse or Copy and Paste the files you want on the CD or DvD.
this depends on what you want to copy if its a cd or a dvd you will need the burning software that will support this if you just want to copy a file click start all programs accessories open windows explorer navigate to the file select it right click select copy then you can copy it to another place on your computer
hope this helps
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.modem-help.co.uk/mfcs-A/Aztech/DSL-208U/
Computers &... | Answered 6 hours ago
Bonjour, I have recovered? an aria gel Ag 75 air conditioner last year. It worked very well? ? share a small loss of water. This year, we put it back on the road and it's cooling down? hardly the coin ... which is very embarrassing because we have a b? b? 19 months. We do not arrive? lower the temperature below 26 degrees. I feel that there is a slight loss of warm air l? o? the hose fits into the appliance ... Can you help me? Thank you. Have a nice day
Computers &... | Answered 10 hours ago
Dodge 2004 Stratus SXT Logo
7 questions posted
Top Dodge Computers & Internet Experts
D. E. Hev
gbob59
Marvin
Marvin
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Dodge Computers & Internet
Most Popular Question
04 stratus sxt will not idle
  • Computers & Internet
