can't stabilize dryer rack in whirlpool duet steam dryer. can't completely close door without rack...
(More)
can't stabilize dryer rack in whirlpool duet steam dryer. can't completely close door without rack coming loose.
My frigidaire crown series gas dryer will heat and turn, but I've noticed that the drun ''sags'' to...
(More)
My frigidaire crown series gas dryer will heat and turn, but I've noticed that the drun ''sags'' to the front and down. This causes clothes to sometimes get caught in the gap between the drum and the door lip, as there is a significant gap at the bottom and the drum is basically resting on the top of the door. Is there some way to realign the drum so that it is straight? I've taken apart the machine and noticed that there were some plastic runners on the top of the door lip that have been completely worn through because of the friction of the drum on the door, which I guess acted as guides. I can't imagine that the drum was meant to slide along these plastic things. I took the drum off the little axle that holds it up in the back. This part is really floppy, like a ball in socket joint or something. I just don't see any active structural support for the drum. Is it supposed to sit on the door lip and that is what keeps it straight?
frigidaire gas dryer trouble shooting ,gas dryer is taking too long to dry clothes problem:I checked...
(More)
frigidaire gas dryer trouble shooting ,gas dryer is taking too long to dry clothes problem:I checked the machine for blockage. There was a blockage just past the lint trap there was a piece of foam insulation glued to the back of the duct it had partly come loose and was blocking the air flow I pulled the loose piece out and while I had it apart I did a very good job of cleaning the front I then pulled off the back of the unit and cleaned it out very well. I re installed the back and checked out the dryer .I also removed and cleaned the vent to through the wall and the hose to the vent. I listened for the gas to ignite on start up I heard ignition. i went outside and checked for warm air blowing out the vent it was blowing hot air out of the vent so i thought all was fixed .It is still taking a very long time to dry the clothes I checked the timer it is rotating on its own (timer motor is ok) I took off the timer after noting all wires .and I checked all the settings for resistance across the contacts they were all about 0.08 ohms none were burned or dirty .I am at a loss as what to do next
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the...
written by jsrock516
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power...
written by MNTECH
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if...
written by DRRXR
1. Disconnect electrical power to dryer. 2. Remove the lid. 3.On the front panel there is a circuit board (moisture sensor control board) with a six...
written by gregorymholt
This
advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE
220-240VAC power cord (US Standards).
3-Prong or 4-Prong ?...
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean...
by wikihow
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected...
by wikihow
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the...
by wikihow
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about...
by wikihow
Tips on how to prevent the dryer cord and terminal block from burning out.
Steps
1. The cause of the dryer cord wires and the terminal block for...
by wikihow
Welcome to Action Appliance Repair. We have bee... Read More
Welcome to Action Appliance Repair. We have been serving the greater Hartford and Springfield area for over 40 years. We are dedicated to working around your busy schedule. Please call now to receive the $25.00 discount coupon available. We are family owned since 1961. Call now for your free ph
Washer and Dryer repair specialists.
Why hire som... Read More
Why hire someone else to fix your appliance when you can do it yourself? And we can help!
Download a step by step tutorial loaded with pics at www.shop.washermd.com
Our focus will always be to provide top-notch qua... Read More
Our focus will always be to provide top-notch quality service and customer satisfaction of repair services to our customers and partners on Warranty/non-Warranty Dimplex heaters, TV & Electronics, HVAC, Electricity, Home & Industrial Appliances, Sports & Exercise Equipment, Treadmills, Spas & Saunas, Office & Computer Peripherals.
