20 Most Recent
A D S DVD Xpress DX2 Questions & Answers
Cw0005 unable to detect usb
what is unable to detect. Is it the TV you are hooking up to or is it the DVD player that can not detect something.
No Audio Recording on ADS DVD Xpress DX2...
Check the registry key:
HKEY_CURRENT_USER\Software\ADSTech\CapWiz3\Params
Values should be:
"m_fUseUleadAudioEncoder"="0"
"m_fUseUleadMuxer"="0"
"m_fUseFileWriter"="1"
Be sure to backup the curent values by exporting the key values before changing them.
DV001: unable to initialize usb
I wish i knew the answer. The product is garbage. It did work until i reloaded XP but always had frame creep in iPOD mode.
I had these problems before and it fixed its self after a while.
Garbage.
Problems with previewing/capture with ADS DVD Xpress DX2
I'd suggest removing all your other USB devices. I had heard that a Netgear wireless internet transmitter in another USB port could interfere with the ADS recognizing the signals from the video player or camcorder.
I had no picture preview at first. Then I tried unplugging my internet transmitter from the other USB device on my computer. It worked like a charm and started previewing right away.
I also found I had better luck with the old-fashioned composite video cable versus the S-video cable. Picture still looks great though after transfer, so sometimes old fashioned still does the job.
Good luck.
The vcr input do not work
it could be a problem with the connector itself, try connecting many devices to it and if it doesn't work, check that the connector isn't loose.If it is,then is probably not going to work unless you get inside and fix the connections.
