20 Most Recent HP iPAQ 111 Classic Pocket PC Questions & Answers
Are you using the factory adaptor to charge the device? The reason I ask is that some aftermarket chargers don't have the required amperage output on the USB port to charge some devices. If you are using an aftermarket charger, try purchasing one from HP directly or look for a charger with a USB port power rating of 4-5 amp. They can be purchased on eBay or Amazon for around $10.
If you need further help, reach me via phone at https://www.6ya.com/expert/joe_9bb563198cdbfc8e
HP iPAQ 111... | Answered on Jan 27, 2018
why not ask HP on the real HP forum.
this product is dead now, mostly, only the rare posts show up.
but you can ask, there.
here
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=ipaq
we are not HP here.
HP iPAQ 111... | Answered on May 21, 2017
Soft reset Perform a soft reset
A soft reset stops all running applications, but does not erase any programs or saved data.
NOTE: Be sure to close all running applications before performing a soft reset.
To perform a soft reset:
1. Locate the recessed Reset button on the HP iPAQ.
2. Use the stylus to lightly press the Reset button.
Hard reset
To perform a hard reset and return the HP iPAQ to factory settings:
Press Win + OK + Record together.
While doing that, press reset button and hold for 3-4 seconds.
Release reset.
Release buttons.
NOTE: Do not release the buttons until CLEAN REBOOT appears on the screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
HP iPAQ 111... | Answered on Feb 18, 2011
Remove the RAM access panel, you will see your ram chips and above these is the wlan controller and directly beside it a small black chip that says Nvidia. This is your graphics chip. We want to leave these COMPLETELY exposed at all times (you might as well get used to just not having the panel on for this fix).
From a cold start (i.e. the computer is completely off and unpowered) boot once, wait about 5-10 seconds. This will allow the motherboard to build up some heat... If you touch your graphics chipset you will notice it's started to warm up. Now go ahead and power the computer down, it's not going to boot on this attempt, but we got the solder warm.
Again power the computer on, and wait a few seconds. This time you should hear your fan magically kick on (assuming the fan is still working, as it is in mine). AFTER, and only after you hear the fan rev up to full speed, begin applying FIRM pressure with your index finger to the gpu (the black chip that says nvidia). Just wait a few seconds and voila, your HP POST screen magically appears.
I've had to do this with this laptop for nearly 2 years now. It never takes more than one to two tries to get it to start up. A word of warning: Do NOT close the screen, you only have about a 5% chance of it actually coming back on when you open it back up.
I'm aware this is a "quick and dirty" fix. If you have the patience and the cash you should just send it in to HP and have them fix it for you. If you have the skill, you should reflow the chip to the motherboard and fix the problem yourself.
If you're like me and you're lazy and broke, this fix will do the trick for the rest of the laptop's lifetime. :)
HP iPAQ 111... | Answered on Jan 09, 2011
Have you tried resetting your iPAQ? You do that by pushing the little button on the side with the stylus. The screen will go blank for a bit, and then windows will restart. I had bought mine used, and when I got it, I had the same problem in that I never got the screen that let me select the wireless network. It fixed mine. Once it is working again, try selecting "View WLAN Networks" again, and you will see a list of networks that it can hear. If the SSID Brodcast is enabled on your wireless access point, you will see your network there. If SSID is not enabled on your WAP, you will need to type in the name of your network before it will find it.
Hope this helps. Sorry it was so late in being posted.
HP iPAQ 111... | Answered on Nov 02, 2010
I've found these informations. Hope they can be useful to you....
Regards, Carlos
HP iPAQ 111... | Answered on Aug 27, 2010
If you haven't already done so, try to uninstall and reinstall WMDC on your PC. Reset both your PC and PDA, and try again.
Just my 2 cents... Carlos
HP iPAQ 111... | Answered on Apr 16, 2010
Hello :
Try to reset your device to it's default factory settings .
good luck
HP iPAQ 111... | Answered on Mar 05, 2010
I did not know that I needed to do a soft reboot on the PCC. Once that happened, everything loaded at once. I don't know where it came from, but it all loaded.
HP iPAQ 111... | Answered on May 21, 2009
What model HP iPAQ?
HP iPAQ... | Answered on Oct 28, 2013
HP iPAQ 111 Classic Pocket PC Logo
30 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iPAQ HP
  • iPAQ HP
Most Popular Question
ipaq 111 hard reset
  • Computers & Internet
