20 Most Recent
RIM Blackberry Curve 8300 Questions & Answers
Blackberry mobile phone
To remove the network restriction from your Blackberry Curve 8300 use unlock code.Specify IMEI number,which country and network it is locked now.Get unlock code from the site
Unbblock.com and unlock it easily.
Unlock blackberry 830 curve
To unlock the Blackberry Curve 8300 ,Buy the unlock code for Blackberry 8300 from the site
Mobile-unlocker.com and unlock it.You can enter the unlock code following the instructions below:
Warning : Do not enter any wrong unlock
codes on your Blackberry 8300 Curve mobile phones. If you enter over a
certain amount of wrong unlock codes on your Blackberry 8300 Curve
mobile phone, your phone may get hard locked and sometimes become
unusable.1 - Switch on your Blackberry 8300 Curve
without any Sim card.
2 - Go to
Settings.
3 - Go to
Options.
4 - Select
Advanced Options.
5 - Select
SIM Card.
6 - Hold the ALT Key while typing in MEPE or MEPD or MEPPE or MEPPD (
not case sensitive ) ( you will not see text appear on screen while
typing ).
7 - You will then be presented with a prompt "
Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
8 - Your Blackberry 8300 Curve will now be unlocked.
Blackberry curve 8300 no signal only sos.
I took it to the original operator who checked the imei ,and they told me the data package was cancelled because the phone was under a business plan of 2 years and someone unlocked the phone so they blacklisted it.
Now I have to make a new contract and all will be resolved.
Thanks hope this helps.
CANNO MAKE OR RECEIVE CALLS
Hi there Check the battery if that is OK go to the place where you set your calls and sounds.good luckkolbrun
Unlock black berry 8300 curve
Go to
blackberrymep.com and buy your unlock code, they will send you an unlock code specified to your BlackBerry along with a fully detailed guide on how to enter the code using the keypad of your BlackBerry .
I am the owner of
Unlock as in use for another carrier? And where did you get this "unlock" code?ALL paid unlocking services are a scam. The only people to unlock correctly is your carrier. Your carrier takes your request, sends it to RIM. RIM then sends them the unlock code. And in about 24 - 48hrs you'll get an email with the instructions and code.So... If your Blackberry OS is "Nuked" your gonna have to reinstall the OS, or get another phone.Nuked OS Re-installation instructions:http://crackberry.com/blackberry-101-lecture-12-how-reload-operating-system-nuked-blackberry
Track ball on my blackberry curve is sticking
Debris gets stuck under there. Get a can of "forced air" blow it on there while rolling the ball. If that doesnt get it out.. There are youtube videos on how to take the trackball out and clean it, but be careful. The 1st time I did that, I broke a lil prong off the housing trying to get it off.. and some of the parts are very tiny, and try to roll away. So be cautious if you go that route.
I want to unclokc my
Well if you are tied to a particular network all you have to do is call up the customer help line of the service provider and ask them for the unlocking code, which will be provided to you for a nominal amount of money.
You can also get the
unlock code through online..........i will suggest the website. which is doing good service .....you can approach
this website.
My blackberry ball doesnt scroll
Chances are it's clogged with dirt and other debris. I suggest using a Q-tip© lightly dipped in rubbing alcohol and run it around the ball and move the ball and just clean it off. That should help.
If not, the ball probably needs to be replaced
It dropped in some water
Try to take it apart into the smallest pieces you can and put it in a place it could dry up, to tell you the truth probebly its dead but if its dry and still doesnt want to turn on take it to a mobile fixing store
My blackberry is not receiing
try this ? > find: manage connections and click it make sure "mobile network" has a check next to it but if its unchecked, clikc it to checkmark the box then enjoy!
