20 Most Recent
Vertex Standard VX-5500 Mobile Two Way Radio Series Questions & Answers
VX-5500 LowBand change power to 20 or 50 watt to suit power amplifier.
The channels can be programmed for either low or high power on a per channel basis. Perhaps I do not understand what you are doing? It would be easy to program each channel to 20 watts. I would take the high power and turn it down since the low power setting from the factory is usually under 20 watts.
While transmissing 'E7" is displayed in vertex repeater. how to rectify this problem?Manual says it is PA Unit Problem.Pls tell me a solution for othis problem.
This error arises when the PA module draws abnormal current. I had this problem because of a bad solder joint in the harmonic filter that is located directly following the PA module. Because of that, the PA sees a mismatch on the output. The VSWR sensor will not detect this because it is placed AFTER the harmonic filter. In my repeater this harmonic filter was inside a shielded module that was really difficult to remove. After I removed it, it turned out one of the caps in the filter was not soldered properly. I am not saying this will be the case in your repeater, it could be another problem but for me this solved the error code issue.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
