20 Most Recent
Eiki LC XNB1 LCD Projector Questions & Answers
EIKI LC-XNB1 BRIGHTNESS
Hi Will39
What you should keep in mind is that this Projector has only got 800 Ansi Lumens wich is not much and to make this worse it is a LCD Projector as well.
Ask your lamp supplier if they can insert a new lamp and check if it gives a better image at all.
If it doesn't , there is'nt really much you can do except buying a new unit with more Ansi Lumens and a better Contrast Ratio as this Eiki's Contrast Ratio is only 250:1 where the standard these days are 2000:1
LC-XNB4MS projector has a yellow
this has soething to do with bad timing of the lcd panels on the prism block. This is a common problem for this model.
You will have to replace the entire optical, which is very costly.
better invest your money in a newer model
I have an eiki lc
this depends on the signal type coming from your sources
best is using component signal ( Y-Pr-Pb) , by using the right cables and right settings for video inputs in the projector menus.In basic this should be possible.
Projector causes buzz in sound
buzz in sound is often caused by ground-loops, try to isolate audio
cables with so called groundloop isolator transformers ( 1:1)
available at high end audio shops or car audio centres
