FixYa.com
Acer XD1150 DLP Projector
All Products > Acer > Multimedia Projectors
Problems with Acer XD1150 DLP Projector?
Search inside Acer XD1150 DLP Projector Knowledgebase
Troubleshooting and Support
Solved Problems for Acer XD1150 DLP Projector RSS Feed Post a New Problem
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
my problem is that the Image is not...
my problem is that the Image is not stable, on my projector, any suggestions?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
Epson EMP-82e locked out
One of our staff turned off the projectors power. He then proceeded to input the wrong security code and the projector...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
green tint
I just purchased an epson powerlight s1. All the highlights are green. I tried adjusting the color and tint, but nothing...
1 Solution
CONNECT CABLE TO MY PROJECTOR
HOW DO I HOOK MY CABLE UP TO MY MITSUBISHI DLP PROJECTOR MODEL HC1500
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Acer XD1150 DLP Projector RSS Feed Post a New Problem
vertical flickering line
i'm using a DLP ACER XD1150projector. I've been using it for 7 months now. My problem is that there's a vertical image...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Product MPN
MPNEYJ3901001
Key Features
PlatformPC
TypeDLP Projectors
Weight4.8 lb
Form FactorPortable
Display TechnologyDLP
Image Brightness1800 ANSI lumens
Contrast Ratio2200:1
Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen)
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · PAL-B · PAL-I · NTSC 4.43 · PAL-D · PAL-H · SECAM L · NTSC 3.58 · PAL-G · SECAM B · SECAM D · SECAM G · SECAM K1 · SECAM K
Image Size (Diagonal)23.1 in. - 302 in
Screen Distance3.28 ft. - 39.37 ft
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
HDTV Formats720p · 1080i
Video ModesCinema · Game
Native Resolution800 x 600
Technical Features
Operation Noise31 dB
Front Panel ControlsKeypad
Interfaces
InterfaceUSB
Video InputComposite Video · 15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video)
Lamp
Lamp TypeSHP
Light Source Life2000 Hours
Light Source Power180W SHP
Other Features
Special FeaturesOn Screen Menu
Projection MethodCeiling
Dimensions
Depth9.4 in
Height4.8 in
Width9.1 in
Acer Contact Information
Main support number408.432.6200 1.800.733.2237
Support FAX408.922.2933
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
