20 Most Recent
RCA H125 MP3 Player Questions & Answers
Hey
Hi, you can check the battery if the cell is too low to power it up, it will not come on. If you can get another battery to test if the batter is still functioning properly.
If it is the battery, when you get a new one. Make sure you charge 100% before you use.
Also you can check the power. the charger might be faulty too.
Take care.
File system corrupted
try getting the firmware and updater from the manufacturer and reloading the firmware
"File not found!"
press and hold on/off for more than 10 seconds to re-set it
If that doesn't work the f
irmware may need to be re-installed
MP3 Playlist Problems
on page 26 of the
manual it describes in detail how to save the playlist.
If this is not working the
firmware may be corrupt and you will have to reload it
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM •
RCA Audio...
Answered
on Jan 15, 2024
