20 Most Recent Asrock ALIVENF6G-DVI Skt AM2 Nvidia NF6100-430 onboard 256MB shared VGA 8 channel audio mATX Motherboard Questions & Answers
0answers
Usb stoped working
Be the first to answer 1/27/2014 3:01:20 AM • Asrock... • Posted on Jan 27, 2014Be the first to answer
Wiring schematics for the ALiveNF6G-DVI
Hello the user manual can be downloaded here:http://www.asrock.com/mb/overview.asp?cat=Manual&Model=ALiveNF6G-DVIAdobe reader is needed to read the content.Other files like the drivers, can be downloaded by selecting download, in the top left corner.You just have to select your windows system.Good luck
2/9/2013 4:00:12 PM • Asrock... • Answered on Feb 09, 2013
Alive nf6g - dvi lan problem
Get online and got to www.google.com Inthe google search box type: "Acer Support" (without thequotes). Look for downloads and drivers. Enter your model numberand operating system when requested. Download and install the drivers
3/31/2012 1:02:58 AM • Asrock... • Answered on Mar 31, 2012
Audio driver
2/10/2011 1:00:37 AM • Asrock... • Answered on Feb 10, 2011
Installed 500GB SATA and a new copy of Windows 7
This motherboard doesn't need additional software to be installed on Windows 7 Platform, it should be automatically installed without any extra software. It's clearly mentioned on the Windows 7 Compatibility Center (Click Here for more info). Since the drivers readily came packed with Windows 7, you don't need the Motherboard Disk.
You'll not find the drivers on the Asrock Official Website either (Click Here).
If you have problem, let me know with the details.
Good luck.
Thanks for using FixYa.
11/15/2010 4:00:17 PM • Asrock... • Answered on Nov 15, 2010
Little or no connectivity
Hello. If you're not using an ethernet cable make sure you have the proper usb drivers for the modem and that you modems 'ID' (mac ID) has been registered with comcast. What your pc is probably registering is the fact that it is acutally hitting the comcast servers. All that means is that you're really getting out into the world, but since comcast doesn't have your modem on file it will not let it through. you may also want to recheck your firewall settings, and reset everything in the line. this means modem, any routers, or hubs, your pc and any other pc you may be networked with all at the same time then power them up one by one. don't login until everything is turned on. if you are networked this will pose a few different problems
11/27/2008 2:10:13 PM • Asrock... • Answered on Nov 27, 2008
Asrock h110 disable on board video using cards for mining only
real asrock mobo told ,just the intel chipset code H110the bios controls that in bios disable iGPU. no cpu told either as some have no igpu at all.like xeons, and some mobo can run both i3+ and zeons.see this search at asrocksee how your post has no real clues?https://www.asrock.com/support/index.asp?Model=h11029 mobo made based on only intel chipet.
5/7/2022 4:02:49 PM • Asrock Computers... • Answered on May 07, 2022
Asrock h110 disable on board video card
double posted you?of 29mobo not one told.https://www.asrock.com/support/index.asp?Model=h110the bios page,labeled, igpu (disable /enable ) is there.some mobo allow zeon here with zero igpu.but not yoursthey make h110 ,mobo just for useless now, bitcoin mining.watch the netflix movie how the blocked mining,then save moneyalso learn what ROI is?
5/7/2022 3:59:28 PM • Asrock Computers... • Answered on May 07, 2022
3answers
No display on my Asrock P4I45GV
Check Ram and fun if not properly installed
5/7/2022 2:12:39 PM • Asrock Computers... • Answered on May 07, 2022
2answers
Asrock G31M-S No Display/not Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO. If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
5/7/2022 1:13:35 PM • Asrock Computers... • Answered on May 07, 2022
MY ASROCK MOTHERBOARD OUTPUT DEVICES IS NOT WORKING
3 post all the same mobo and all 3 same reasons. and all 3 same answers. zero no I added one, coin cell is dead at 7 years, you are 2004 to 2018 late to the party. 14 year old battery is 2 times spec life. for sure.
12/29/2021 4:42:52 PM • Asrock Computers... • Answered on Dec 29, 2021
Factory reset windows 8.1 error
Wipe the hard drive and do a clean install, not repair.
9/21/2017 1:33:46 AM • Asrock Computers... • Answered on Sep 21, 2017
This is my system, -K10N780SLIX3 wifi Mobo -Gtx
swapping out parts, try with different power supply pull the ram reseat it maybe one at time. different memory slots. change one part at a time with good working part, never assume any part is good.
4/19/2017 12:36:24 AM • Asrock Computers... • Answered on Apr 19, 2017
Crack windows 7 activate
That would be ******* and we don't so that here. Sorry.
7/9/2016 6:11:53 PM • Asrock Computers... • Answered on Jul 09, 2016
Instalar windows 8
Si ustedes quieren activar Windows 8 necesita una clave de producto, te tengo este enlace para obtener algunos m?s estables: https://plus.google.com/117868268119072465334/posts/XuMyoTaUjN7.
6/8/2016 6:53:27 AM • Asrock Computers... • Answered on Jun 08, 2016
Asrock ALIVENF6G-DVI Skt AM2 Nvidia NF6100-430 onboard 256MB shared VGA 8 channel audio mATX Motherboard Logo
Popular Tags
7 questions posted
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Asrock Computers & Internet
Most Popular Question
alive nf6g dvi lan problem
  • Computers & Internet
