20 Most Recent
Toshiba Satellite L45-S7409 Notebook PC Questions & Answers
I DONT HAVE SOUND ( AUDIO OUTPUT DEVICE IS NOT INSTALLED)
Check out either the audio drivers (start > settings > control panel > system > hardware > device manager >check for exclamation mark in front of the audio device) and update if nessersary,
Or the audio mixer levels from the audio related icon at the taskbar. In case it's missing go start > settings > control panel >sound devices > mark the checkbox "volume icon at the taskbar"
After the above you will be able to hear audio from your computer but in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
12/20/2021 8:13:45 PM •
Toshiba...
Answered
on Dec 20, 2021
Connect tv hdmi
Does this laptop support it? You need a cable that is up-to-date and supports HDCP so make sure your TV and laptop are on the same standard. Plus, make sure your laptop is at a resolution your TV can accept.
12/16/2013 9:45:08 PM •
Toshiba...
Answered
on Dec 16, 2013
My laptop it dosent asept windows xp
SATA HARD DRIVE - XP INSTALLATION The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
12/26/2012 12:04:23 PM •
Toshiba...
Answered
on Dec 26, 2012
My screen dont come on when i hit the power button
Please unplug the power adapter first then remove the battery, then press and hold the power button for 30 seconds. Then plug the power adapter then plug it to the power outlet, now press and hold the power button at least 30 seconds, just to make sure that your laptop will turn on.
Thanks.
9/28/2011 5:52:24 AM •
Toshiba...
Answered
on Sep 28, 2011
Where can I downloadToshiba Satellite
A recovery CD would contain a copy of windows, and therefor can not just be downloaded. You need to find the one that came with the pc, or see if there is an recover option when the pc boots e.g. F11 to recover.
Otherwise buy a new copy of windows :-(
3/13/2011 9:20:19 PM •
Toshiba...
Answered
on Mar 13, 2011
Lost password to the bios...
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
6/8/2010 3:55:45 PM •
Toshiba...
Answered
on Jun 08, 2010
Need instructions for keyboard toshiba satellite
No need for the instruction manual. When your going to use the numbers that are inside of the letters, hold down the the FN key and then push the number that you want to be displayed. For example holding down the FN key and then pressing the L key produces the number 3 for me. Try your keys out and see what you get.
6/2/2010 2:01:33 AM •
Toshiba...
Answered
on Jun 02, 2010
How to boost incoming wifi signal
The strength is what it is.
The only way is to move the notebook closer to the wireless router, or to move the router closer to the notebook computer.
Or, buy a MIMO (Multiple Input Multiple Output) router, which emits a stronger signal.
4/10/2010 4:13:49 PM •
Toshiba...
Answered
on Apr 10, 2010
My intel display driver has stopped working
if you use "windows update" and select "custom" at the first screen instead of express it will find the appropriete intel video driver for you . after it does it's search, click on the "hardware,optional" link on the left side of the screen. then select the intel video driver by checking the box next to it in the left pane.
then click review & install updates. you may need to restart windows after the update.
Regards..
4/4/2010 5:07:34 PM •
Toshiba...
Answered
on Apr 04, 2010
How do i reset my laptop without a recovery disc
Use a Windows installation CD; it must match the Windows version on the Windows Product Code label on the bottom of your laptop.
You will also need to download the device drivers for your model laptop from the Dell WEB support site, make sure the download the correct XP or Vista version of the drivers which matches the Windows version you are installing.
4/1/2010 12:37:39 AM •
Toshiba...
Answered
on Apr 01, 2010
I need set the output signal from the pc for tv
I had many issues trying to do this as well. There were several times when I tried to do it and it didn't want to accept the connection. You may try enabling the 2nd monitor connection in the settings for the graphics properties. I tried several different things and then it finally worked. Sorry I am not much more help other than that. You might also try the function key and the F5 key i believe. (monitor/LCD/TV key). Hope this can give you a little more insight into getting the problem fixed.
Thanks,
Ben
3/29/2010 3:00:13 AM •
Toshiba...
Answered
on Mar 29, 2010
Why is the karaoke music from my external hard
Playing through the USB port can cause all sorts of "problems" also ensure NO other software is competing for the CPU time. It is always best to play work on use, anything or file, from the actual hard drive. simply copy the files to the HD, and use them from there Also more RAM is always beneficial Also make sure you have the most up-to-date Codecs installed too.
3/16/2010 1:03:44 AM •
Toshiba...
Answered
on Mar 16, 2010
I want to install xp sp2 in tosiba satilite L45
After you might have put in your XP CD in the CD DRIVE then your restart your system and once is coming on again it prompt for you to press anykey so as to boot from the CD you insert into it then when you press anykey it start immediately and you follow the commands or if is not bringing the press anykey to boot from CD then from restart press the F6 so for you to adjust the setting to Boot from CD as the first Booting sequence and Hard disk as the Second booting device ok then it you press ok and save changes and continue . i hope you will understand like that or probably still use the factory setting by pressing F11 from start up and it will load your system to the way the manufacturer produces it well functioning.
2/22/2010 10:27:08 AM •
Toshiba...
Answered
on Feb 22, 2010
How can i install xp sp2 in toshiba satellite L45
what you are to do is to put the Bootable disc into the cd drive and turn off the system later after turning it off re-ON the system and the program running setup will tell you to press any key to load from CD and you press anykey then it loads the operating system and reformatted the system and follow the instructions command and your system is back.
if there is anything try reposting ok
2/22/2010 10:05:26 AM •
Toshiba...
Answered
on Feb 22, 2010
My computer crashed and I am tryingto recover the
Pull the hard drive, the data should be ok. You can take it to GeekSquad at Best Buy and theyll be able to help you out. Other wise go on ebay and buy a UBS adapter for your slim drive, plug it into a desktop and transfer files.
2/4/2010 9:55:57 PM •
Toshiba...
Answered
on Feb 04, 2010
