20 Most Recent
Toshiba Qosmio G45-AV690 17" Laptop PC Notebook Questions & Answers
My screen brightness its lees
Then brighten it. You brighten it by Holding Down either FN, CTRL or DEL key + Hit the corresponding key for brightening the display.For example on my computer I press and hold the FN Function key while I hit the UP Arrow key to brighten the screen.The brighten/darken keys normally have the icon of a circle with sprockets around it like the sun or it looks like a washer that goes between a screw.
When laptop says no bootable device
It means that you do not have a hard drive that can be booted to start the OS, or that your had drive is defective, or the boot sector of the hard drive is missing or corrupted.
Wireless capability turned on
You just got wireless turned on ?
Does this mean you just added a wireless router to your existing wired network ?
You may need to turn off the DCHP server in the wireless Router and give it a unique ip address eg if wired router is 192.168.0.1 then make wireless router 192.168.0.2 with gateway ip set as 192.168.0.1 then make wired dhcp router not lease out 192.168.0.1 - 192.168.0.20 make subnet mask the same also for each router.
Beep codes
Did you solve the problem? I have the same here, in Brazil.
I have a rj111 cord jsrAA.where do i plug back in
On the right hand side after the USB sockets there is a drop down flap. Underneath are the RJ11 modem and RJ45 network sockets.http://www.notebookcheck.net/fileadmin/_processed_/csm_Anschl._rechts_01_129c1d9a1d.jpg
I had friends over and they were logging into
Reboot your computer, OPEN YOUR CHROME WEB BROWSER, AT THE TOP RIGHT HAND CORNER CLICK THE THREE BARS, SCROLL DOWN TO SIGNED IN AS CLICK ON IT, SCROLL DOWN TO USER, SIGN IN AS ''NEW USER'', CLOSE BROWSER..OPEN FACEBOOK AND LOGIN...
My Toshiba F45AV410 won't boot after turning it
It's a vague description...A/If you see a blank screen and you can hear some noises... it will be the screen (LCD) , Plug it into a computer Monitor and see if you get a picture off it. B/If you get nothing, no sound and no screen it will be power related. It is either your external power supply or the internal power in the computer. If you have another external power supply, try that or if it is the internal power supply you will need a repair person to fix it.
Space bar not working
There is a lot of users that show Toshibas keyboards are the worst.So if you had tech skills you can DIY and change it if not visit your repair shop.
