20 Most Recent
Toshiba Satellite A215-S5815 Notebook Questions & Answers
I can't get wireless connection to my laptop why?
A "Diagnostics" can identify the cause of the problem, or (errors) and try to correct, the "Internet" connection. Go, to: Control Panel, select "Network and Internet." Select, (“view network and task status”), “choose a task”, to performed, from the (left) pane. You can start a quick diagnostic by clicking on the connection "diagram", Computer---WNC---Internet. “You can (setup) personal computer, internet settings.” I hope this Fix it.
1/23/2010 11:26:52 PM •
Toshiba...
Answered
on Jan 23, 2010
I forgote my bios password what shall ido
you have to dis assemble the notebook and remove the prom battery looks like a watch battery for about 2mins re-install boot up and ur bios password is reset
12/29/2009 10:14:20 AM •
Toshiba...
Answered
on Dec 29, 2009
I need a mother board for a215-s5815
I would suggest you look on ebay as you may get a bargain there if lucky.But make sure the item is genuine and also it's a reputable seller.
12/10/2009 2:03:43 AM •
Toshiba...
Answered
on Dec 10, 2009
Toshiba satellite A215-S5815 WLAN issues with Win.XP SP2
Just use "Atheros 802.11a/b/g,b/g Mini-PCI/PCIe Driver v5.3.0.67 or later for Windows XP"and get the problem solved.You can either download the driver from Atheros site or search for that on google.I am using Windows XP Pro with SP3 on the same mechine and the wireless is working fine.In case of any problem you can contact me on
[email protected].
12/20/2008 5:00:39 AM •
Toshiba...
Answered
on Dec 20, 2008
Car plug in on 1997 intrepid
no you ussually dont hear anything when you plug in your vehicle. you will know in the morning if it worked or not. block heaters don't make enough noise for you to hear.
12/16/2008 8:11:55 AM •
Toshiba...
Answered
on Dec 16, 2008
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
