20 Most Recent
Lenovo N200 T2310 Notebook Questions & Answers
Where is the care button located?
you talking about the Think Vantage button? This is usually the blue
button labeled "Think Vantage" on the upper left of the keyboard. Right
after the media or other buttons. the upper left has the Esc
key, 3 speaker buttons (mute, volume down and volume up and then the
blue rectangular Think Vantage button.
On Booting up my Lenovo
Welcome to Fixya
This means that the operating system got corrupted. Possible cause of this is virus issue or invalid regisrty entry. You may try to boot the computer to safe mode and see if it is still working. Keep tapping F8 while you trn on the comuter then press safe mode to boot the OS to that mode. Once you are alraedy at the safe mode. Go to start then clickall programs. Click accessories then click system tools. Click system restore thjen select a date where you want to restore the computer. If you cannot access safe mode then what you need there is the recovery disk of the computer to restore it from factory default state.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Once water fell down on
Only if you are lucky the fault will be resolved because if any water falls on electronics it would conduct very easily and hence the possibility that some damage has already been done. But to make an attempt we can first of all remove off the battery and remove the covers very carefully. remove the keyboards and look at the connecting cords to the mainboard. Use a good volatile solvent like petrol dipped in cotton buds to wipe out all the dirt+moisture inthe board. Use a hairdryer to warm off all the moisture and keep for drying at least for a day .Repeat the work once again before you reset the boards back connecting carefully. Now lets hope that your keyboard works or else the next option will be to connect a bluetooth wireless keyboard. Hope you try this out. Good day
I am running XP on my lenove when i start up it
once its up and running,how fragile is it?meaning can you pick it up,close the lid ,open lid turn,upside down and set back down with it still running,or will it shut off,if it shuts off i would say you have a hardware problem,if it can handle a little abuse and still run,then im thinking virus ,trojan,or maybe just errors on harddrive,,is battery ok?try removing it ,see if it makes any difference,,hope this helps.let me know more details,and ill try to helo further
Power not switching on
remove your battery and plug your charger. it will switch on if has no hardware problem. if it does switch on, then you will have to note that it is you battery that has a problem
thank you,
wonder
Where can i find lenovo care button on my keybord?
Are you talking about the ThinkVantage button? This is usually the blue button labeled "ThinkVantage" on the upper left of the keyboard. Right after the media or other buttons. On my T61 the upper left has the Esc key, 3 speaker buttons (mute, volume down and volume up) and then the blue rectangular ThinkVantage button.
I have a lenovo n200 and upgraded my os to vista
Hi freind!
Actually when you upgrade your OS from the origional one that you get on ur machine and the CD along with it, the drivers for your hardware have to be re-installed.
However,in the driver cd that you got along with your Laptop will not have it!! So you'll have to download the respective drivers for ur hardware from .then transfer it to your machine with the help of a USB srive or some other thing.Then you can install it!! Be sure to download the Drivers for your HARDWARE only!!
I had the same problem but overcame it by doing the same as told above!!
Hoping this helped.Any help regarding the above steps , feel free to ask them.
See ya.
Lenovo care button not working?
you have to install the mainanance partition bzw. restore the system from the recover cds this will install.
System utilities
N200 (type 0769)
Hotkey utility
Windows Vista, XP, 2000
* 24 Nov 2008
v2.09.0002
Lenovo System Interface Driver
Windows Vista, XP
01 Sep 2008
v1.01.0805http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-67855
How to connect an onn wireless mouse to a lenovo chromebook? i tried doing this 3 times and still wont connect.
Firstly, try turning over your Bluetooth mouse and find the power switch. Make sure it's turned to ON.
You should see the optical light turn on (usually red). Place the mouse back flat on your mouse pad.
On your Chromebook, select the lower right corner of the taskbar. In the window that pops up, select the Bluetooth icon.
If the Bluetooth status is currently off, enable the toggle switch to enable Bluetooth. Once enabled, you'll see a scanning status as your Chromebook looks for active,
nearby Bluetooth devices. When your wireless mouse appears, you can select it to pair and connect to it.
Once your Chromebook has made its connection with your Bluetooth wireless mouse, you'll notice the mouse pointer moving when you move your mouse
Lenovo ThinkPad L510 boot menu disabled
Repeatedly tap the F1 key when the Lenovo, ThinkPad, ThinkStation, or ThinkCentre logo appears, The computer may beep once to indicate that it will boot to BIOS.
How to Enable Boot device List F12 Option
The following example shows a system that has an option to enable or disable the Boot device List F12 Option.
Go into the BIOS to enable Boot device List F12 Option (option is usually under the Startup tab).
How to remove keypad from Lenovo thinkpad
Removal steps of keyboardLoosen the screw to the unlocked position to unlock the keyboard frame. Turn over the computer. To reveal the screw heads beneath the frame, use the flat-head screwdriver to slide the keyboard forward by 2.5 mm (0.1 inch). Use the cross-head screwdriver to loosen the screws.
Can we undo window 7 anytime upgrade
no once you have upgraded, it cannot be degraded to the previous version. and do you think this will solve the issue? you had the same problem even before with windows 7 home basic genuine version,then how could you think about this problem.let me tell you that genuine or piracy version of windows does not harm the machine but it is *********** board which is creating problem.this symptom "sudden shutdown" suggests that you need to change *********** board if it is not repairable.
