20 Most Recent
Rangemaster Classic 110 Kitchen Range Questions & Answers
Cooker trips main fuse board when top rings are
How many hotplates are there on the cooktop? How many elements are being used, oven and grill included, when the fuse blows? Is there one or two circuit breakers or fuses in the fuse board for the range? Need to know these details to be able to help.
Ok. I inherited my
Most of these timers have 3 buttons, the hand and the plus and minus buttons. Try pressing the minus and plus buttons at the same time. The display should flash. Then adjust the time with the plus and minus buttons. If this doesn't work just try different combinations of pressing 2 buttons. If the timer is not faulty on of these combinations will work.
Fan not coming on in fan oven Second (smaller)
fan motors seized or slow. Turn ovens on with the doors open and switch them on individually,you should see the fans turn behind rear panels, if not see if elements redden up as test if not they may be faulty also.
Rangemaster classic hood 110, doesn't fit as our
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
The convection oven of my 110 electric cooker is
conventional cooking uses the outer/grill element plus there is one under the base of the liner to radiate heat upwards... if the top element is heating then the lower element is faulty thats why it never gets to temperature...
I have a Rangemaster Classic 90 dual fuel that has problems igniting the gas hob.
Remove the flame spreaders and rings from the 3 rings you use the most, including the faulty one. Put them in a large pan cold water, add a teaspoon of dish liquid and slowly bring to a simmer. As soon as it want to boil over, blow on it and turn the heat off. Leave it to cool. Scrub with a plastic pot brush making particular attention to the holes. You had a blocked one which is the one that directs the gas to the spark igniter. Rinse and dry them, and replace to the hobs.
