20 Most Recent
Sharp 19 in. LCD HDTV Questions & Answers
No stand by light tf wont turn on with or without the remore
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
My Sharp 19" LCD Tv
Bad capacitors in the power supply are common on most of these small Tvs. I have not repaired this model, but my suspicions and expeience tell me where to start! Thanks for asking and show all hands of support!
Hi
I have sharp lcd tv
Hi this normally happens if the refresh rate is to high in your graphics settings for the computer, try going into control panel > appearence and personalization > click on adjust screen resolution > click display and see if your TV is listed there and select it if it is, click advanced settings click on the monitor tab and adjust the screen refresh rate to a lower setting then click apply. you may have to keep trying different refresh rates or screen resolution to get the tv to work.
many computers use manufacturers software sometimes found in the lower right of the taskbar right click there or double left click to open properties find you tv model , it should be listed somewhere click on it and navigate to the screen refresh rate and try all the lower settings usually 25hz works for the uk and euorpe and 30hz works for other countries other frequencies (refresh rates) my be higher depending on the tv you have but one of them is sure to work.
Also make sure you have the latest drivers and software for your graphics card/board in your computer.
Hope this helps
Midge.
Let me know if you managed to get it to work!
Thankyou and good luck.
Is the Sharp LC32D47UT 32-Inch
Quite possibly as it can cope with NTSC and PAL
The elegant AQUOS® LC-32D47UT easily enhances the decor of
any family room, living room or den. With a 16:9 aspect ratio, HDTV
resolution of 1366 x 768 and breathtaking color purity, it is a
next-generation TV to carry you into the high-definition future. The
LC-32D47UT features a high contrast ratio, 6ms response time and wide
viewing angles. The LC-32D47UT includes built-in
ATSC/QAM/NTSC tuners, 3
HDMI™ and 2 HD Component Video inputs as well as a D-sub, 15-pin input
for PC compatibility. The LC-32D47UT features a black cabinet, and the
included table stand easily removes for wall mounting applications.
Features
- True 16:9 - widescreen aspect ratio with 1366 x 768 HDTV resolution.
- Built-in ATSC/QAM/NTSC Tuners - provide access to DTV and available analog TV channels.
- High Brightness - Sharp LCD TVs are very
bright, so you can put them virtually anywhere - even near windows,
doors or other light sources - and the picture is still vivid.
I have a Sharp 19 with no sound on some channels.
Make sure it is not on the SAP or secondary audio setting. Some channels broadcast English and Spanish or English and Silence. If you are set on the second audio broken you may hear nothing. Check your manual.
People faces and a lot of other items on the
On this television you would need to remove the Comcast digital cable box. This tv does not need it. Then you will press the menu button and choose either the channel or the setup category. You will then need to locate the auto ch memory or ch setup subcategory. Then you will select it by pressing enter after scroling down to it. Next you will scroll down to automatic search or ch search and press enter. Select search start for just digital channels and press enter. It may direct you to select yes and then enter. After the television is done searching the 135 channels it will come back to channel 2.1 or the lowest channel you receive. You can then go through your channels with the ch button on your Sharp remote control. The picture can further be adjusted with the av mode button on your remote if you press it repeatedly if you remote control has one.
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Tried to connect Sharp 19
I had the same problem when I got one of these a few months back. Once get it all hooked up give comcast a call at: 1-800-266-2278(or 1800comcast) they will have to update some codes and reset it to get it up and running.
Should take less than 5 min's once you get a rep. on the phone.
If you need any further help give me message in the comments
I have a 19
you will have to replace the screen it suffered a crack in the screen itself on impact!
What are you spose to do when the bulb runs out
Rare that it will. The ballast circuit is more likely to die, both parts can be repaired by a sharp service centre.
By the time then life of the bulb comes to an end the pannels will be weakened to the point where you will get a bluish screen.
What type of cable for laptop to Tv?
In order to hook a laptop or any computer to a tv you have to have the right video card with the correct video connections like hdmi or s-video. If you don't have those connections then you can't hook a laptop to a tv.
Have lost sound on several od our channels
Thank you for your concern. Yes the problem is solved. It turns out the cable company did something to change the settings on our audio. Don't ask me what or how they did it but someone told us about it and how to correct it
Again thank you very much
