20 Most Recent
KitchenAid KUDS03FTPA Built-in Dishwasher Questions & Answers
The water sprayers are not working and their is
he spray arms are probably clogged with food particles see if you can clen the holes in the arms..Then purchase a bottle of dishwasher cleaner form your local supermarket it works great and cleans all the **** outta your machine make sure you run hot water from tap closest to machine and use it in an empty dishwasher.Follow all instructions on bottle you will be amazed at how clean your dishes will come out with the first wash after the cleaning..cost per bottle is about 8.00
Kitchenaid KDPM604KPS dishwasher stops minutes into cycle
I couldn’t find any error code 2H but I did find an error code H2O. This code means insufficient water pressure. If the display reads 2H, it usually means the start delay function is turned on. The dishwasher will turn on in 2 hours if door is closed. This dishwasher is advanced. To understand all operations you should read the user guide or manual.
10/13/2022 10:19:23 AM •
KitchenAid...
Answered
on Oct 13, 2022
What is the correct button sequence etc to do a panel reset on a kitchenaid KUDE60HXSS1
Pick any 3 consecutive keys (except Start or Cancel, then press them in the sequence 1, 2, 3, 1, 2, 3, 1, 2, 3. The dishwasher will go through a self-test and short cycle, and reset itself.
