20 Most Recent
EXPOBAR Brewtus II Redesign Questions & Answers
I wish to lower the steam pressure slightly how do
Inside the machine their is a presurestat which is connected with a pipe to the boiler and inside the pressurestat their is an electrical contactor which turn on and of the heating element. this pressurestat have an adjusting screw on the top which have he signs + and - if you turn it to - then you will reduce the presure insite the boiler. However the normal pressure should be between 1.2-1.3 bars.
Water not filling into boiler
Many posibilities for your problem. The two main posibilities are:
1. The boiler water level sensor it might be dirty or full of scale, need to be removed and cleaned.
2. The water in solenoid valve might be blocked from dirt or scale so must be cleaned
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
