20 Most Recent Mr. Coffee ISTX95 Questions & Answers
hey greeniis1 i dont know if you ever found the parts you needed but i did .. http://www.smallappliance.com/product.asp?pid=12479&cur=USD&cam=GA_B_mr_coffee_parts
Mr. Coffee... | Answered on Feb 12, 2011
They are available in most larger department stores where Mr Coffee is sold..
heatman101
Mr. Coffee... | Answered on Sep 18, 2010
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Mr. Coffee... | Answered on Jan 04, 2010
I am sure abut this but most coffee maker work by pouring the amount of coffee you like to make.If it's a automatic then you have to put the coffee in it and pour the water also, then set the time you want it to start.Other wise just pour in after you put the coffee in and turn the switch on.
Mr. Coffee... | Answered on Mar 15, 2009
3 beeps means plugged water line. Take off the bottom of the coffee maker with a small phillips head screwdriver. Use pliers (I used needle nose type) to remove the wire clamps holding on the silicone water tubes to the hot plate. In my case, the water line from the reservoir to the plate was clogged with something I couldn't see until I blew on the hose and it popped out, could have been scale, grounds etc Clean with vinegar. Back in service!
Mr. Coffee... | Answered 3 days ago
Time for a new coffee maker
Mr. Coffee... | Answered on Jul 19, 2018
Mr. Coffee ISTX95 Logo
15 questions posted
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Pierre Laplante
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Mr. Coffee Coffee Makers & Espresso...
  • Mr. Coffee Coffee Makers & Espresso...
Most Popular Question
broken lid
  • Coffee Makers & Espresso Machines
