20 Most Recent
JVC GZMG150US Hybrid Camcorder Sd Or Hdd 34x Op 800x Di Flash Media Questions & Answers
Jvc everio software for windows 7
, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatiblity". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D
Power not on or USB device not compatible
I think your battery is 100% OK, if the power supply is perfect there may be problem with the switch, clean it with contact cleaner spray often press the switch several times.
if the switch contacts are not connecting, this will help it to clear it.
open the cam, check the power supply on the main board, there is a
small fuse on the circuit board test it with. eventually we have to suspect the mother board. if so should change it.
I can not access the menu on my jvc everio gz-mz37u to reformat the hard drive and HDD error is still showing, please help.
first of all my advice is: if you keep any electronics devices without usage for a long period, you must detach the battery/power supply.
in this case I think the hard disk may be faulty, if you can open the camera and takeout the HDD connect with an HDD dock connect the dock to your system, in normal condition your computer will detect the hard disk, if so you can save the contents to your computer or you can format it, if it is not detecting your computer it means the HDD is physically damage. please change it.
Everio media browser 3 be
I solved my problem by changing the setting from PAL to NTSC in the Everio media browser (the unit was purchased in the US but the software was set to PAL).
