20 Most Recent Archos AV700 TV Digital Media Player Questions & Answers
I want bay this archos like a parts....
Archos AV700 TV... | Answered on Jun 12, 2011
Hi there, please try the following to reset your archos player -
If the unit is frozen while on, press and hold the STOP/OFF button for at least 15 seconds. This should make the archos player reset and hopefully solve your problem.
Hope this helps
Archos AV700 TV... | Answered on Mar 19, 2011
first u will check ur charger or adapter
its function or not
and then u will check plu-in hole
its any dust particals
Archos AV700 TV... | Answered on Nov 17, 2010
go to link # 1 and scroll down to Operation in green , click on How do i update the firmware on the AV700 TV? read it . this is the firmware update link # 2 KEY NOTE you might be able to find the problem you have on the first link
# 1 http://www.archos.com/support/support_tech/faqs/en/faq_AV700TV.html?country=us&lang=en
# 2 http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Archos AV700 TV... | Answered on Sep 24, 2010
does it get really hot, if it overheats too much it probably will turn off as a safety feature
Archos AV700 TV... | Answered on Sep 20, 2010
You can get the manual on the link below.
http://www.instructionsmanuals.com/u2/pdf/photoPC/Archos-AV700-en.pdf
You can get accessories on the links below.
http://www.boxwave.com/products/easyfinder/buy-best-archos-av700-accessories_2782.htm
http://www.pjbox.co.uk/Archosav700-accessories.htm
Good Luck and please rate 4 thumbs up for the free answer
Archos AV700 TV... | Answered on Sep 05, 2010
It is possible that the archos can't handle that big of a file. You can try to compress the file or see if the player can handle a smaller file type.
Archos AV700 TV... | Answered on Jun 08, 2010
its because u need to reset it and if that dont work take it back and dont get the same one...
Archos AV700 TV... | Answered on Oct 27, 2009
try upgrading the filmware version to the latest one off the archos site
Archos AV700 TV... | Answered on May 22, 2009
The problem turned out to be the charger, problem now solved, thank you
Archos AV700 TV... | Answered on Apr 19, 2009
It's not an easy fix, and doing so would void the warranty - it would be best to call archos and see if you are still under warranty to get a replacement. If you do not want to do this, I would go to a repair shop or the Geek Squad - they will charge an arm and a leg. Unlike other electronic products, there is no way to unscrew this unit or 95% of other Mp3/Mp4 players.
Archos AV700 TV... | Answered on Apr 16, 2009
You can try doing the firmware upgrade, but it doesn't work for all mp3 players. Contact Archos for addl assistance.
Archos AV700 TV... | Answered on Jun 30, 2008
Disable the automatic synchronization option in Windows Media Player. Go to www.microsoft.com and enter either "automatic synchronization windows media player" or "manual synchronization windows media player" as you search term for click-by-click directions with pictures.
Short version: Connect mp3 player to computer, highlight sync tab, click on little black arrow and bring down drop-down menu, click on Set Up Sync, uncheck box that says "automatically synchronize blah blah blah"...
-Tha Mp3 Doctor
Archos AV700 TV... | Answered on May 26, 2008
Hi
If you buy an archos travel cable/kit it has an adapter whitch will connect to your tv
You can find it on EBAY very cheap
regards
wilf
Archos AV700 TV... | Answered on May 19, 2008
Archos AV700 TV Digital Media Player Logo
Popular Tags
28 questions posted
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Archos Audio Players & Recorders
Most Popular Question
disconnected archos av700
  • Audio Players & Recorders
