20 Most Recent Sony NWZ-B103FBLK MP3 Player Questions & Answers
Install windows xp in virtualbox :)
Sony... | Answered on Nov 01, 2018
You can't boot from an mp3 player. Interesting idea though.
Go into your BIOS and set the first boot device to your hard drive,
Sony... | Answered on Mar 26, 2014
Windows will see the device as USB storage. Firmware is not an issue.
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Sony... | Answered on Sep 29, 2013
I bought a NWD-B103F sony mp3 player last year. The mp3 player was working just fine till the same problem as discussed had popped out recent after 2 weeks i had left it untouched. Even I had followed the solutions given, I updated the firmware to version 1.2, I even tried the "pressing play button while inserting the player to USB port" method, the problem remained. I sent the mp3 player to the nearest sony service centre (still under warranty), they fixed it in one day and contacted me to get back the mp3. For my disappointment, I brought the player home and tried it out, the problem still unsolved. So, I'd like to know is there any other useful solutions because all other solutions given I had attempted resulted failure. Thanks for all the concern!
Sony... | Answered on Oct 30, 2012
I had the exact same problem with my girlfriends sony nwd-b105 mp3 player. I fixed it by downloading the firmware version 1.2, which can be found here at the sony support link below.
http://support.sony-europe.com/dna/wm/nwf/nwf.aspx?site=&m=NWD-B105&site=odw_en_GB&odw_model=NWD-B105
- Backup your mp3 files
- Make sure your mp3 device is NOT plugged in
- Run the firmware executable
- When it asks for it plug in the mp3 device
- Check option: format data area
- Press Start
- When finished, take the mp3 device out and press the power button
- If everything went well it is creating a database again and will function correctly as usual
- Copy your mp3 files back to the mp3 device
- Enjoy your music again!
Sony... | Answered on Sep 19, 2012
if you have the initial executing files that were on your mp3 when you bye,
Format your Mp3 on PC by FAT32 format and copy those on your Mp3 player folder
if not , mail me : hamidjoush@yahoo.com
Sony... | Answered on Jun 04, 2012
Hello every body,
I had the same problem and fixed it using a simple logic.
First Step: Format the Player using the PC. (click with right button on "Internal Device" and select "Format".
Second Step: On the "Internal Device", create this folders: "Music", "FM", "Record" and "Voice".
Third Step: Copy your music into the Music folder.
That`s it!! Go play
Sony... | Answered on Jan 03, 2012
Hi carthagefarm,
This can happen when the file system gets corrupt, what I would suggest you is to connect the device to your computer via a cable and then check if you can find the music files in it.
When you do that , you should copy the files to your computer and then format this music player and then again copy the files in it.
This should solve your problem.
In case it does not , feel free to contact me.
Hope that helps ...:)
Sony... | Answered on Sep 13, 2011
try to make hard reset for it
Sony... | Answered on Aug 31, 2011
The only way to fix a boot error message on an mp3 player is to do a firmware upgrade. If the firmware is available you will find it on the manufacture's website. It's important that your computer still recognize the player when it's connected because the firmware will be have to be downloaded onto the player.
The firmware should be installed then connect your usb player. Follow the steps given on the web. By the way it will be better if you format your player as well during this installation.
I'm using the same model as you and I'm very glad to share you this.. hope you will try!
Sony... | Answered on Mar 28, 2011
the problem your device is of software....all u had to do is,...download firmware1.3 software from net and run the software....when the software run...it will ask for the device you want to install the software.insert your walkman it will install the software on it and......wallah it will start running as it was before
Sony... | Answered on Dec 23, 2010
hi ...... i have sony walkman nwd-b103f that problem is boot error plz solve the problem......
Sony... | Answered on Oct 18, 2010
i have a problem when i start my mp3 it gives format error even i have formated my mp3 but it's giving me the same error please tell me its solution...
Sony... | Answered on Sep 05, 2010
try using sonic on your computer.
Sony... | Answered on Feb 18, 2010
Hi, the songs files has been corrupted and need to be copied again into your mp3 player, i advice you delete the corrupt songs and re-copy the songs again on your mp3 player.
Compliments and wish you best of luck
Sony... | Answered on Dec 25, 2009
Sony NWZ-B103FBLK MP3 Player Logo
78 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony walkman nwz b135f mp3 walkman
  • Audio Players & Recorders
