20 Most Recent
OKI C5550N Multifunction Printer - Color LED - 32 ppm Mono - 20 ppm Color - 1200 x 600 dpi - Copier Questions & Answers
FATAL ERROR 923
923 - black image drum lock error
make sure the black drum is in correctly
make sure black toner is locked
reboot machine
OKI 5550mfp Fax Problems
error 209 - Media Table Download Failure MediaTable Download to PU failed. Reboot.
CU firmware detected an anomaly in behavior in PU (including a violation of communication protocol between CU and PU).
are you suing unusual sized paper?
How to reset fuser life error
the best soloution is to replace the unit with a brand new one as reset fuses are difficult to work with on fuser units but if you search the internet you might be able to find a reset kit from alibaba or amazon
OKI C9800 CYAN TONER SENSOR ERROR
remove drum units and clean optical sensors located at the back end of he drum slots and clean corresponding reflective plates on drum units
How to reset drums on oki c5950
Amber's solution worked on an oki c5150 as well as on her 5500.
At first, I got into other menus and did not see what she'd described. I cancelled out, then re-ran her procedure following its steps EXACTLY... At the very end, I may have seen one additional message - "EXECUTE" - which I "entered" to launch the process. Printer now works while I find instructions on how to replace "just the drum".
The OEM drum assembly is very easy to change but costs about $125. I found (on Universal Ink & Toner) a drum-only replacement for $30, but there was no instruction sheet with it. This solution has allowed me to keep working while I figure out how to install the new drum. Print quality was excellent right up until the manufacturer's internal counter shut printing down. Quality remains excellent after applying the above solution.
THANK YOU AMBER
Dave
