20 Most Recent
Brother MFC7220 - 1200 x 600 dpi / 20 ppm / 5-in-1 Multi-Function Center Mono Laser Printer - Refu Questions & Answers
Need to installed cd drive
on this page
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc7220_us_as
you can download driver.
Select your operating system and language and download it.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
I want to install printer without a disc
Hi
You cannot set up a printer without a driver that needs to be install in your computer before it prints.
Just download to brother website for free printer installer and install it to your computer.
regards.
Printer was saying clean scanner i open the
You need to clean the scanner glass where your original feeds into the fax.Sounds as if the sensor for the rear door is faulty or the back door is warped.This is a common problem on certain Brother machines and i would suggest that you take it to a dealer for repair.
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
How do I print envelopes on Brother MFC6490CW
Load the envelopes in like paper, tell the printer the size of these to set the paper size, then whatever you're using to print on the envelopes, set up the page size the same size as the envelopes. You should then be able to print on envelopes
How to remove printer head on brother mfc 495 cw
1. Unscrew these three 12.1mm screws holding the control panel in place.
2. Lift up the front panel from the device.
3. Before removing the unit, apply 2 or 3 pieces of tape to secure the top and bottom of the unit.
Visit my computer
Brother mfc490cw printer show offline and error
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Brother MFC490cw
Right-click on the printer in the folder and uncheck the "Use Printer Offline" option to place your printer online and available.
