20 Most Recent Samsung GT-S5300 Galaxy Pocket Questions & Answers
Use this method to hard reset your Samsung Galaxy Pocket S5300 phone: Enter *2767*3855# , or use volume up + power + home and wipe data
good luck
Mr Difallah walid
Samsung GT-S5300... | Answered on Dec 02, 2018
for onkey 7s reset samsung galaxy pocket
Samsung GT-S5300... | Answered on Sep 15, 2018
how to solve double tap to unlock problem in samsung gt-s5300
Samsung GT-S5300... | Answered on Sep 12, 2018
Here is a FIXYA 2013 series of messages that MAY help you!
Solution for onkey 7s reset
Anthony
Samsung GT-S5300... | Answered on Aug 21, 2018
www.samsung.com/us/support/
Samsung GT-S5300... | Answered on Apr 04, 2018
Please read http://androidforums.com/vibrant-support-troubleshooting/172809-crash-user-fault-not-kernel-panic-upload-mode.html I think, hope it is related to how it 1st came about to displaying the message you're receiving on your handset, all the best.
Samsung GT-S5300... | Answered on Mar 26, 2018
Were you trying to recover the photos in your chat history? You can use WhatsApp Pocket to recover them from the iTunes backup or your device directly.
www.fireebok.com/whatsapp-pocket.html
Samsung GT-S5300... | Answered on Nov 21, 2017
You didn't indicate the type of phone. Using the google account registered on the phone becomes a problem since in nearly all cases the data connection on the phone was left OFF. You may know your account and password but the phone isn't connecting to the internet to confirm. You are now left with the only option of hard resetting the phone and obviously you will lose all the contacts and installed applications too. But that is not a problem. If you had synced your contacts to your google account, once you register into your account again, all your phone numbers will be available again. Always be syncing your contacts with your google account. Newer phones models can be recovered by a technician without losing anything.
Samsung GT-S5300... | Answered on Sep 28, 2017
Samsung GT-S5300... | Answered on Sep 01, 2017
try this & good luck :)
turn off your phone with hold the power button-----take battery out-----turn on again with press the power+volume up button, hold until samsung logo appear then release the button-----type *#9900# on call menu-----select "choose debug level" then switch to normal.
Samsung GT-S5300... | Answered on Jul 03, 2017
http://www.androidauthority.com/how-to-install-google-play-store-312812/
Samsung GT-S5300... | Answered on Nov 01, 2016
looks like the phone was not reset to factory default for new user and the phone is password locked to the old owner --if able try to notify old owner so phone can be cleared or you can try to notify your provider for help
Samsung GT-S5300... | Answered on Sep 02, 2016
If you've forgotten your pattern or password lock for your Samsung Galaxy Pocket GT-25300, you may need to do a hard reset. Here's how!
Simultaneously hold down the volume up button, the Home button (the button in the center below the screen) and the Power button.
Keep holding. After a few seconds the logo Samsung Galaxy Pocket; then release the button.
Check your phone boots in recovery mode.
Select "wipe data / factory reset". Use the volume rocker to highlight this option and confirm the selection by pressing the Home button (in this mode, touching the screen does not work).
Select "Yes - delete all user data" in a similar manner on the following menu.Wait a few seconds while the full reset. The phone will return to the first menu.
Select "reboot system now". In a few minutes, the phone will boot normally without asking data from your account.
is its Helpful plz click on helpful
Samsung GT-S5300... | Answered on Jul 26, 2016
Your speaker/mic may have gotten damaged, that often happens to me if mine gets wet. Mine will usually go away after a few days, and if you know it got somewhat wet, try the soaking in rice trick.
Samsung GT-S5300... | Answered on Mar 21, 2016
you can't add a photo which you have sent through Bluetooth as it is stored in a emulated environment. try to move the photo first on your images folder or whichever folder you want thereby removing it from the emulated environment. then go to contacts, tap menu, tap the contact you want to edit, tap the image, tap assign or replace, then locate the images you move and assigned it.
else you can also try the work around.
locate the folder where you stored the transferred photo, tap the image, tap menu, tap set as, there are some options asking you what you want to do, set as wallpaper, etc and one of them is set as contact photo, tap set as contact photo, locate the contact whom you want to assign the image and then tap save.
hope this helps.. :)
Samsung GT-S5300... | Answered on Mar 02, 2016
Perhaps then you should look into a newer phone . many older ones do not have enough memory to work well .
Samsung GT-S5300... | Answered on Feb 12, 2016
Hi Ivan
Please see the following extract from Wikipedia re: your query.
From Wikipedia, the free encyclopedia
112 (emergency telephone number) 112 is the common emergency telephone number that can be dialed free of charge from any fixed or mobile telephone in order to reach emergency services (ambulance, fire and rescue, police) in numerous European Countries, including all member states of the European Union, as well as several other countries in the world. In some countries other numbers previously used also continue to be available; e.g. 999 and 112 both function in the UK. In the United States, some carriers, including AT&T, will map the number 112 to its emergency number 9-1-1.
Samsung GT-S5300... | Answered on Jan 14, 2016
I hope i am wrong but It is a little bit doubtful. Phones even with dual sim have separate 17 imei codes. Anyway, if you are in doubt try to return the phone back. Don't want to judge too early, but It may have been tampered. Best possible way is to return it.
Samsung GT-S5300... | Answered on Nov 06, 2015
Samsung GT-S5300 Galaxy Pocket Logo
430 questions posted
Top Samsung Cell Phones Experts
John Tripp
John Tripp
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cell Phones
  • Samsung Cell Phones
Most Popular Question
phone came from walmart never activated
  • Cell Phones
