20 Most Recent T-Mobile MDA Vario Smartphone Questions & Answers
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
T-Mobile MDA... | Answered on Feb 06, 2011
Hello
PIN, as in the sim card pin? that you can enter 3 times and then it either reports pin locked, or asks for puk code.
If that is it, then you can get puk code by calling the carrier, service provider. First enter pin code wrong 3 times, then enter the puk code you got from service provider.
This will unlock the pin and you will be asked for a new pin.
Noting is deleted from phone or from the sim card.
Everything will work normally.
If this is not a sim card pin code, let me know what pin the phone is asking for.
T-Mobile MDA... | Answered on Oct 05, 2010
It is an registry bug from the t-mobile software..
It has been found on only the T-Mobile branded Raphael's.
How to fix it:
Install an Registry Editor
Here http://htc-raphael-100.handster.com/software.php?id=3199&for=HTC+Raphael+100
or
http://www.phm.lu/Products/PocketPC/RegEdit/
Go to:
HKEY_CURRENT_USER>ControlPanel>Phone
Here is an D-Word registry called: CallIDMatch, the value on my phone was standing on "12". When you edit the value and set it to 8. All of the problems dissappear.
It recognizes every type of storage of contact.
and that is your prob solved ;o)
T-Mobile MDA... | Answered on Aug 17, 2010
tick on the antenna bar..then go to sttings...then services...then network...try selecting manual network...hope this helps!
T-Mobile MDA... | Answered on May 06, 2010
download activesync
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
T-Mobile MDA... | Answered on Mar 22, 2010
either replace the whole lcd screen at a nokia care centre or at a mobile phone store. cost at nokia care centre would be over $200 and at a phone store it would probably be over $150.
if the phone stops at the white screen it is usually a problem with the crystal diode in the lcd screen.
T-Mobile MDA... | Answered on Aug 15, 2009
Findout from MDA site what is the 'reset to factory default settings' is. Remove the memory card and reset. It will do away with the new SW that you installed. You will loose all settings that you made and the SW that you installed. But your phone will be as good as brand new. In case of Nokia the code is *#7370#. Yours may be different.
T-Mobile MDA... | Answered on Aug 08, 2009
in windows, right click on the CD player with you cd in it.
click explore and look for USB Drivers.
Install the drivers and try hooking your phone up again.
Try using a fast USB 2.0 port on the computer.
If this helps please leave a vote
T-Mobile MDA... | Answered on Aug 06, 2009
http://rapidlibrary.com/index.php?q=wiza200+user+manual
here is a web site that you can get instructions
T-Mobile MDA... | Answered on Jul 15, 2009
Phone Lock Reset Wizard Mda Vario T Mobile
instructions for
hard resetting a wizard, which is resetting the phone
thus the phone lock as well.
Dead easy really
1. Press the Comm Manager button (top left)
together with the Voice Activation button (top right)
for 2 seconds.
2. Keep holding the 2 buttons above and press the soft reset
(middle right little hole) with the stylus for another 2 seconds.
3. When the black screen appears it'll ask you to click Send
That's it All done !!
The wizard's going to reboot and reset himself.
Good Luck.
T-Mobile MDA... | Answered on May 17, 2009
hi. i have had the same problem and have had to change the battery twice in the three years i have had it. sometimes the batteries that you can buy off ebay are quite cheap but go off without any warning fairly quickly.last one i have bougt has lasted me 1.5 years without any probs.
my other advice would be to back up your contacts/other sensitive information somewhere safe( your phone SIM for example- which has to be done one at a time for the mda vario)as well just in case.
hope it helps
T-Mobile MDA... | Answered on Nov 26, 2008
Download here
Kindly rate this solution.
T-Mobile MDA... | Answered on Jul 01, 2008
I have exactly the same problem; phoned t-mobile; it's a problem at their end, they are hoping to resolve shortly
T-Mobile MDA... | Answered on Jun 16, 2008
another problem if anyone can help is how to send contacts from mda vario to mda vario III??????? its getting me down!!!!
also having problems with sync so cant load onto pc then copy but it used to wk!!
T-Mobile MDA... | Answered on May 18, 2008
WERE FIXYA NOT T-MOBILE
T-Mobile... | Answered on Jul 10, 2018
T-Mobile MDA Vario Smartphone Logo
29 questions posted
Top T-Mobile Computers & Internet Experts
Marvin
Marvin
markpain
Level 1 Expert
matt
matt
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
MDA T-Mobile
  • MDA T-Mobile
Most Popular Question
t mobile n95 8gb just white screen
  • Computers & Internet
