20 Most Recent RCA CC285 Camcorder Questions & Answers
As I understand your query, you are attempting to use equipment without any of the required peripherals, and without wishing to purchase them.
Good luck.
RCA CC285... | Answered on May 23, 2017
yes you can "Rig" something up,but make sure you are using the right voltage as well as the right milliamps the cam is made to recieve.this is Very important. and of course make sure the wires you are using to power the cam are not touching or crossing each other at any time, and they do not touch the wrong contact in the camera as well. I have found using a piece of cardboard and taping the wires to it, keeps the wires seperated. good luck, and take your time when connecting your wires.
RCA CC285... | Answered on May 20, 2014
This sounds very much like a tape jam and the camera is trying to un-load the tape but it is stuck round the capstan, run the tape back a little if you can, that should release it from it's snag area okay.
RCA CC285... | Answered on Aug 27, 2013
Yes, when both lights are on.. it means the battery is charging. The "charging" light should turn off once the battery is fully charged.
If the "charging" light remains on 12 or more hours later, your battery might need to be replaced.
RCA CC285... | Answered on May 16, 2011
That monster looks old. My guess is that the battery is not holding enough of a charge and may need replacement. Can you plug this into the wall for power? Are you getting any error codes?
RCA CC285... | Answered on Feb 03, 2011
If you have not already tried it, use a wet or dry tape in an attempt to clean the video head, I recommend the dry tape because it is easier on the mechanism. The other option is to use a store bought blank tape and run it on sp mode the fastest speed and let it run through. If you still have trouble, buy a swab kit with cleaning fluid from Radio Shack, open the door so you can clearly see the video head. Now dip the swab in cleaning fluid and put swab against the head "gently" use the other hand "top part" to manually turn the head one or more times around for a deep cleaning and allow several minutes to dry, this a good opportunity to clean the rollers and other parts with Q-Tips and fluid to finish the job. If none of these work it probably indicates a bad video head.
RCA CC285... | Answered on Jan 19, 2011
Do you have a model number? I found a manual for the RCA Pro8, Pro807, from Voxx here: https://voxxintl.zendesk.com/hc/en-us/articles/225487888-Information-and-Owner-s-Manual-for-the-RCA-PRO8-Model-PRO807-Camcorder . The direct link to this manual appeared as https://sc.voxxintl.com/docs/common/PRO807/PRO807_OM.pdf in my browser history.
I hope this helps.
RCA Video... | Answered on Sep 09, 2018
Try Googling (RCA)(model)(manual) without parens.
RCA Video... | Answered on Mar 27, 2018
I am sorry to say that it appears you may have answered your own question, the "hundreds of hours" is the clue.
Consider the possibility that your camera is worn out.
Sorry.
RCA Video... | Answered on Dec 12, 2017
nice question....
RCA Video... | Answered on Nov 29, 2017
It appears to have a built-in USB connector, use that.
RCA Video... | Answered on Nov 10, 2017
I understand you have a problem. What is not clear from your description, however, is the actual nature of the problem. Please can you state it more clearly. Thank you.
RCA Video... | Answered on Jun 15, 2017
RCA CC285 Camcorder Logo
20 questions posted
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
View Most Popular
RCA Video Cameras
  • RCA Video Cameras
Most Popular Question
when battery charger 2
  • Video Cameras
