20 Most Recent
Casio EX-Z1080 Digital Camera Questions & Answers
Need a Manual for Casio Model z-1080
You can download and print the instruction manual in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe Reader Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
My battery charger for Casio
You can use your computer USB post but it has to be USB 2.0 compatible or else it wont charge. you can also purchase a usb wall plug because most standard USB devices usually have an output of 5v. This is a lot better since you wont have to walk around with a computer or laptop to charge your camera, lol Radio Shack around ten bucks.
When I put the camera
Hello
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off.
2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
Kind
regards
Andrea
USB cable is not reading the camera, the cable
kindly check the usb port to the camera if disconnected or not.usually the problem always to the port becuase of excessive force inserting the usb cable thats why the contact point of the the said port was unsolder. if its happen try to solder or bring to the service center.
Camera will not turn on. I have charged the
Your problem may be due to weak/worn out batteries or corrosion on the
battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the
batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, chances
are that your batteries need to be replaced because they're just too
worn to properly power the camera.
And then, of course, there's the possibility that your camera may have
a problem that requires professional repair.
Screen and camera broken
If you dont have a problem with a slight zoom issue, you can push in the lens until itgoes in and your camera should work fine
Lens stuck halfway out Casio Exilim July 20 2009
Question edited for all the typos.
Question moved from Casio computer to Casio Camera.
If you are reading something back in 2009 make sure you aren't reading 'Suggested Answers' as they are often not the item you have. It also sounds like you are giving a testimonial as a new post to someone that is no longer on the Fixya site?
This is your only post, did you fix your camera?
https://www.fixya.com/users/rachel-evans-25235
