Remote control does not activate. Activates other machine so problem seems to be with LED receiver...
(More)
Remote control does not activate. Activates other machine so problem seems to be with LED receiver in DV. What bit do I need to replace
Whenever I try to play a DVD it Reads, and then says either 'No Disk' or Not correct Disk, even...
(More)
Whenever I try to play a DVD it Reads, and then says either 'No Disk' or Not correct Disk, even though in the past it has Read and Played DVD's with no problem.
i have the same problem, i am currently trying to track down a new dvd unit to replace the one in my...
(More)
i have the same problem, i am currently trying to track down a new dvd unit to replace the one in my rh277h, but having trouble finding one
Connected LG RH177 (England) I think in other countries this is the LG RH 1777 to Philips T.V. (2...
(More)
Connected LG RH177 (England) I think in other countries this is the LG RH 1777 to Philips T.V. (2 scart) and normal sky (2 scart). (2 scart on dvd) No sound through dvd on any channel. When record, sound on the dvd records very fast for the picture showing. Have on line manual as misplace mine own copy, or was in the box. Box in the bin. Help!?? :0( Thank you: darkangel3968
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
