On 1 of the tvs, when watching a movie with headphones in you can only hear the music of the movie...
(More)
On 1 of the tvs, when watching a movie with headphones in you can only hear the music of the movie not the talking
I calibrated the monitors in my home. The I try to plug the dvd player in my car and nothing happen....
(More)
I calibrated the monitors in my home. The I try to plug the dvd player in my car and nothing happen. I bought a new plug and same as before nothing happen. What can be the Problem?
when putting a dvd in my system, the system will not read the disk. Even when I try to clean it with...
(More)
when putting a dvd in my system, the system will not read the disk. Even when I try to clean it with a DVD Cleaner it won't read the disk. Any suggestions?
I have the same issue listed in a different thread. There has to be someone out there that has or...
(More)
I have the same issue listed in a different thread. There has to be someone out there that has or knows how to fix.
The unit that can be the main unit when playing the same DVD on both screens won't play DVDs. The...
(More)
The unit that can be the main unit when playing the same DVD on both screens won't play DVDs. The 2nd unit works fine. I can't find any help on the Audiovox page. Does anyone have any suggestions?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
