I dubbed film from hdd to dvd and it is not compatible on the other dvd player. How I have to...
(More)
I dubbed film from hdd to dvd and it is not compatible on the other dvd player. How I have to dubbing
When either setting up and timer starts to record on the hard drive the disc draw opens and closes....
(More)
When either setting up and timer starts to record on the hard drive the disc draw opens and closes. LG model RHT387H
LG RH1999H HDD/DVD recorder cannot receive all TV channels, esp the digital TV, why? How can I make...
(More)
LG RH1999H HDD/DVD recorder cannot receive all TV channels, esp the digital TV, why? How can I make it work? I want to record the new Channel 7 Two (in Sydney). I tried both connecting the DVD recorder to the set-top box and directly to the antenna, but doesn't work either way.
The dvd player will not recognise the recordings from a disk I have recorded from the unit itself -...
(More)
The dvd player will not recognise the recordings from a disk I have recorded from the unit itself - it brings up a message saying - 'no payable titles'. I have tried several disks.
I want to record programmes from Sky on the timer. How do I do that? I do not have a connection with...
(More)
I want to record programmes from Sky on the timer. How do I do that? I do not have a connection with any other TV station....
Hi, I have lots of movies on the HDD of my DVD Recorder RH-1999. Instead of writing them to DVD+RW...
(More)
Hi, I have lots of movies on the HDD of my DVD Recorder RH-1999. Instead of writing them to DVD+RW and then copying the VOB files to my PC, I removed the HDD from the recorder & put it in a USB Caddy. However, my PC sees the new hardware but does not assign a Drive letter to allow me to view/copy the files. Any idea on how to fix the problem? Also, any alternative way to rapidly copy my movies from the HDD to a PC? Thanks for your help. Iqbal.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
