Power goes out and cant turn unit back on. Green light continuously blinks then after a day or two...
(More)
Power goes out and cant turn unit back on. Green light continuously blinks then after a day or two goes completely off and then after a while ligts up and blinks again. At one point the tv just came back on by itself and then after a day or two it went off again into blinking green light mode
LG 32LG3000 LCD - will not recognise CAM module inserted in CI slot - is this a software or hardware...
(More)
LG 32LG3000 LCD - will not recognise CAM module inserted in CI slot - is this a software or hardware problem. (for ESPN / Setanta CAM)
my tv screen flashes on and off and the tv turns itself off on the 3rd time, sound still works...
(More)
my tv screen flashes on and off and the tv turns itself off on the 3rd time, sound still works during the flashing on/off til the tv goes out.
We have an LG32LC75 TV. Sometimes it locks up so you can not change channel with the remote control...
(More)
We have an LG32LC75 TV. Sometimes it locks up so you can not change channel with the remote control unless you turn the TV off and reboot. At other times the remote will not turn it off and you have to disconnect from the power source
I bought a 32 inch hd lcd lg tv in the UK and want to see if i can update the firmware to accept...
(More)
I bought a 32 inch hd lcd lg tv in the UK and want to see if i can update the firmware to accept australian hd channels
Does ayone know if it is possible to convert an LG 32LC7D (HD TV) to accept PAL signals rather than...
(More)
Does ayone know if it is possible to convert an LG 32LC7D (HD TV) to accept PAL signals rather than NTSC. I bought this in US last year and have brought it to UK. Maybe I can upgrade firmware??
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
Michael from Queens, New York Purchase a LG 42" HDTV connected it to Direct TV service, while on the regular service no problem, but went to...
written by mwv2001
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
