20 Most Recent
Sony KDL-32M3000 32 in. LCD Television Questions & Answers
My Sony Bravia is stuck on channel 2 and won't
I have the same problem. I have the Sony Bravia KDL-40S4100. I can't get it off channel 2. It won't work with the remote, and it won't work on buttons on the top of the console either. The power button on the remote is still able to turn the TV on and off, but aside from that, everything else is frozen.
My Sony KDL-32M3000 has dark
It will be either BM board (Video Processor board) or Tcon Board (top side of panel). I have similar problem...my TV turns on, lamps turns on (you can see them from back side panel holes) but just a dark blue picture appears with no image (like picture when external input is selected without signal), no OSD appears....some times I can heard audio (using Antena).
I'm thinking getting the BM board.
Can't remove the subtitles from my sony bravia tv
Hello !
I would you to try this open the back disconnect the power cable to the video card of the set then put it back then on it .
Remember when doing this make sure there's no power coming in from the wall socket otherwise u will be short circuited
good luck
Why would the volume stop working on my TV?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Tv comes on then picture goes out but still has sound but no picture
Sounds like a back light failure. To verify this, turn on the set, dim the lights in room. Shine a bright flash light on the screen, if you see a faint picture on the screen, you have a back light failure. You either have a blown back lamp, 24v circuit fault, or a failed inverter board.
Unable to change picture aspect
If remote has the aspect button it will do this depending on signals--some boxes preset the aspect for the signal they are outing to your TV---4x3 for example may not be able to be switched to full or 16x9.
