20 Most Recent
Panasonic TH-50PZ750U 50 in. HDTV Plasma Television Questions & Answers
Built in speakers no longer work
we had the same unint in our store with the same problem.
the cause was a manufactior defect.
a heatsink was shorting to a electroletic capasitor on the main audio amp.
fix was to isolate with a non cunductive plastic over the capasitor causing the short.
hop this helps.
1/9/2009 11:26:30 PM •
Panasonic...
Answered
on Jan 09, 2009
Random Side Panel Inputs
You either have a bad Main board or simply a bad touch control button in other word one of your side buttons is defective and it is blocking any other signal to the main board, but usually its a bad main board. In some cases ther is a FIRMWARE update from Panasonic, you may want to call Panasonic or check there website for any type of FIRMWArE UPDATE.
Panasonic TC-L32X1 The picture blinks on and off but it still has power
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in '
Mosaic' view. It will make search easy.
After thunder storm
http://electronicshelponline.blogspot.com/ Check the site in '
