20 Most Recent Crosley Radio CR2406A-PA Director CD Recorder in Paprika CR2406A-PA Questions & Answers
Where can I get a schematic of the power board E315942?
Find somebody from Manila, Philippines and ask them to get you one at Raon. If they don't have it in stock they will make it for you.
7/22/2015 7:00:45 PM • Crosley Radio... • Answered on Jul 22, 2015
How do i fix the cd holder when it is stuck
The gears usually dry up or get stuck with hair. You need to open the panel and re-grease it.
7/22/2015 6:55:37 PM • Crosley Radio... • Answered on Jul 22, 2015
How to manually open eject Crosley CR248 CD drawer
  1. Uh, I think you already have a solution but the following may help someone else.
  2. Ensure that the device is powered on.
  3. Press the "Function" button (28/58) to set the unit to CD mode.
  4. Press the "Open/Close" button (19/48) to open the CD drawer.
  5. Insert a CD into the tray with the label side facing up.
  6. Press the "Open/Close" button again to close the CD drawer.
If the above steps don't work, you can try the following:
  1. Unplug the device from the power outlet.
  2. Wait for a few minutes.
  3. Plug the device back in.
  4. Press the "Open/Close" button to see if the CD drawer opens.
If the drawer still doesn't open, there might be a mechanical issue with the device. Look for the Fixya advise referred to above. If if that doesn't work, in that case, it's best to contact Crosley's customer support for further assistance.
12/4/2023 6:11:51 AM • Crosley Audio... • Answered on Dec 04, 2023
I have a Crosley CR80 gold series 4-1 record player and the records won't spin
Turn the arm that holds the element and needle careful to the far right and the turntable will spin. This is a safety feature for protecting the needle.
12/1/2023 6:54:13 AM • Crosley Audio... • Answered on Dec 01, 2023
Where to get a tape player band for Crosley CR704B-WA radio?
Band? do you mean the 'drive belt? https://www.google.com/search?q=crosley+cr704b-wa+tape+player+drive+belt Or you buy generic by length / diameter...
10/27/2023 3:23:29 AM • Crosley Audio... • Answered on Oct 27, 2023
Crosley cr1704a-wm full size led jukebox
This is an internal circuit switching failure that requires a Crosley servicer to repair. You may have difficulty finding one because Crosley is just a brand name attached to equipment manufactured offshore.
3/29/2023 12:43:17 PM • Crosley Audio... • Answered on Mar 29, 2023
Cd will load but not play
The CD could be scratched or there or there is a problem with the laser and it needs a new laser.
2/17/2023 12:35:56 PM • Crosley Audio... • Answered on Feb 17, 2023
2answers
How to adjust speed the record player back to normal on top my Crosley McQueen stereo?
It sounds like the belt driving the unit might be out of place or connected wrong. It could be the belt is slipping caused by wear and thus needs replacing.
12/19/2022 8:44:00 PM • Crosley Audio... • Answered on Dec 19, 2022
I have a Crosley CR66 that won't power on at all (nothing works), anyone else have this same problem and know of a fix?
Check The line in switch in the back. If not using the auxiliary input, make sure the line-in switch, located on the back of the system near the auxiliary cable, is in the off position.
9/12/2022 3:14:56 AM • Crosley Audio... • Answered on Sep 12, 2022
2answers
My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
6/11/2021 7:13:43 PM • Crosley Audio... • Answered on Jun 11, 2021
I need the instructions for the Crosley Director 2405B Audio Turntable Deck.
CROSLEY DIRECTOR CR2405A INSTRUCTION MANUAL ...
https://www.manualslib.com > ... > Director CR2405A
View and Download Crosley Director CR2405A instruction manual online. Director CR2405A turntable pdf manual download.
Crosley Director CR2405C Instruction Manual (Page 2 of 48 ...
https://www.manualslib.com > ... > Instruction manual
View and Download Crosley Director CR2405C instruction manual online. Director CR2405C turntable pdf manual download.
4/5/2021 5:52:45 PM • Crosley Audio... • Answered on Apr 05, 2021
The motor on my Crosley cr74 does not turn. belt is OK
Hello Tom, you would have to measure if the engine gets power, also control the key that drives the engine when it starts Check if you can move the motor shaft with your hand, to confirm that it is not locked Good luck with the checks Greetings Franco Dosil Hola Tom, tendrias que medir si le llega alimentacion al motor, tambien controlar la llave que acciona al motor cuando arranca Fijate si puedes mover el eje del motor con la mano, para corroborar que no esta trabado Suerte con los chequeos Saludos Franco Dosil
4/19/2019 3:00:46 AM • Crosley Audio... • Answered on Apr 19, 2019
Crosley Radio CR2406A-PA Director CD Recorder in Paprika CR2406A-PA Logo
7 questions posted
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Audio Players & Recorders
Most Popular Question
get schematic power board e315942
  • Audio Players & Recorders
