20 Most Recent Amana Radarange Microwave Oven Questions & Answers
Yes there are fuses inside.
There are lethal voltages within Microwave ovens that can stay charged up for many days. If you do not understand the hazards, get it repaired by a qualified electrician.
Amana Radarange... | Answered on Mar 30, 2018
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
Amana Radarange... | Answered on Dec 05, 2017
I'm sorry, I don't have an answer, but my radarange also began this odd behavior about a month ago... my son is a mechanic has almost forbade me to use it, stating he gets a headache everytime he opens it.... Once the range stops cooking, I open the microwave to get the food out, and the range immediately turns back on, lights on, and carousel turning! I have NO IDEA if the microwaves are engaged at this point???!!! But suppose I need to find out ASAP!
Amana Radarange... | Answered on Oct 08, 2017
replace touch pad
Amana Radarange... | Answered on Aug 13, 2015
The external cover has to be removed to gain access for lamp replacement.
Amana Radarange... | Answered on Jan 13, 2015
If it is sparking dont use it check for any metal or tin foil in it if the is none replace it
would be cheaper than fixing
Amana Radarange... | Answered on Feb 07, 2014
You gave no model number or other detail. There are MANY possible causes. Fuse, safety switch, power supply, magnetron, control board. Check the fuse first. There is DANGER working on any device like this, and certain skills necessary. That's why they pay us the big bucks, NOT. If you insist on fixing it yourself, do a google search for your model oven, and download the manual. Please follow safety guidelines. Parts and repair help are available at:
http://www.repairclinic.com/
Amana Radarange... | Answered on Jan 16, 2014
Amana Radarange Microwave Oven Logo
167 questions posted
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Microwave Ovens
Most Popular Question
f 3 amana radarrange
  • Microwave Ovens
